Results 1 to 11 of 11
Thread: vtec problem
    Default vtec problem
    Ok i just bought a 95 integra with a gsr swap it has a chipped ecu but not tuned.whenever you get on it vtec is kicking in at like 4200 which should be 5200. but when i do hit vtec the rpms go all crazy and jumps from 4 to 8 or 9. what could cause that? its like vtec is not kickin in like it should could it be the chipped ecu?
    Senior Member khaxnguyen's Avatar
    clayton county
    it depends, if you have a crazy all motor car you could just be loosing traction when vtec hits. otherwise it would be a bad distributor or ecu programming
    I give out reps....
    Default hey
    it might be the computer the guy said it has a chipped but not tuned.they also had a vtec controller on the car and took it off.but its mostly stock but im planning on turboing it. this weekend if i get it figured out
    try another gauge cluster and check the alternator.
    Default ok
    Quote Originally Posted by mp82
    i got an extra one ill try it.but if it was the alternator what the batt be going dead
    yea, sometimes it's make the gauge cluster go wack then the car run off the battery till it drain, that's when the battery light comes on.
    it was doing it when the guy had it i dont think its that
    Augusta Ga
    change ECU's ..... check VSS sensor also ..check where the vtec controller was and make sure they didnt cut any wires and left them undone ...
    93 sol Si
    95 sol S
    95 sol Si
    Default hey
    thanks they did leave wires undone from the vtec controller but dont know what they do
    vtec controller wiring harness must be removed. map and vtec wires at the ecu must be re-connected (they get cut and run through vtec controller).
    4200 is really low especially if the ecu hasn't been tuned. the tach jumping around sounds like a bad icm/dist. try changing w/ a known good dist and get it tuned.
    i'm assuming you don't have any cel. if you do fix those first before doing anything else.
    HONDATA DEALER/TUNER
    NISSAN REALTIME-NISTUNE
    Default hey
    Quote Originally Posted by scttydb411
    i bought a new ecu its doing the same thing. i ran it out the track friday and it was cuttin out bad. i dont know what it could be but it had no power the rpms where going all wack but i figurad it would of ran faster then 10s lol. my buddy has a stock single cam 4 door civic running 10.5 in the 8th so something is wrong
