Results 1 to 13 of 13
Thread: cluster light dont work
    Im a killer
    Default cluster light dont work
    Ok check this out, i had a cx cluster on my hatch and only the e-brake, trunk light, cel, battery light work. Everything esle is darkness. Cant see nething when driving at night. Than i replace it with a ex cluster and same thing still happen. Than a new problem occur. The temp gauge is reading maximum hot and i didnt ever start the car yet. My intrumental light fuse is not blown btw. Any1 had this similar problem
    grounds
    Augusta Ga
    ^ amen ... theres a short somewhere behind the cluster or maybe in the radio din /.
    93 sol Si
    95 sol S
    95 sol Si
    Im a killer
    alrite thanks rep but can u explain why the temp is reading like that, do i gotta play around with that needle
    Augusta Ga
    a loose ground or a faulty power wire touching a ground will make the needle read hot ./ does the car do it with the key out of the car and it not turned on ? if it doesn't then its more then likely a ground .
    93 sol Si
    95 sol S
    95 sol Si
    good luck sounds like bad wiring somewhere
    Crash
    Snellville, GA
    good luck with it
    1993 Honda Civic EX
    1993 Acura Integra
    1998 DB7 Integra
    1989 Toyota Supra
    1993 Toyota Supra
    thats what I said!
    Quote Originally Posted by suprapower
    good luck with it
    Im a killer
    thanks alot sol for the help...imma look more into it tomor
    IA MEMBER turbob20's Avatar
    LaFayette Ga.
    like they said a ground and also possibly as far as no lights in bezzle it could need a replacment dimmer switch on the left of you stirring wheel on dash. just pop out and plug in new one.
    Im a killer
    o snap when i pop the dimmer switch out, two wire with no insulator are rubbing on each other, guess i found my problem thanks ia
    Augusta Ga
    yaa... reps to no mo honda's ....
    93 sol Si
    95 sol S
    95 sol Si
    LaFayette Ga.
    no mo hondas and me perhaps,lol give credit where credits due. it took us both to git it done but hey its all good on IA,LOL.
