Results 1 to 14 of 14
Thread: 2002 pontiac grand am - wont start
    Clogged t/b is not the answer, nor is the maf sensor. You need to check ALL of the fuses. It could have a blown ECM fuse, which will cause the injectors not to pulse. Spray some carb cleaner, or starting fluid in the intake before the maf sensor, and see if it doesn't try to start.
    make sure the intake tube is connected an the MAF sensors are hooked up! if not it will not run either
    Quote Originally Posted by Init2winit
