Results 1 to 10 of 10
Thread: idle control valve
    Default idle control valve
    how in the **** do i bypass my idle control valve on my 93 honda civic
    dteng Homer Simpson's Avatar
    Evergreen Terrace
    if i remember correctly, you need the iacv for your ride to run properly.
    i just cant afford to buy another right now
    Don Mon SiRed94's Avatar
    Morrow 30260
    Quote Originally Posted by grim91685
    so go to pull a part and steal one... problem solved....
    freezrburn frostbyte's Avatar
    douglasville
    lol damn u beat me too it...
    U JUS GOT DROP KICKED IN THA FOREHEAD WITH A BROKEN CHEETOE!!! [SIGPIC]
    It wont run right without it.
    douglasville
    theres jus some things u jus cant get rid of...
    Senior Member G.C's Avatar
    Forgot
    go to ebay or like what other people said.
    :idb:
    i have one ill sell for 15$. 20$shipped.
    fagNwagN h23bb2's Avatar
    It'll run fine with it blocked off. Mine has for about 6 months and counting.
    1. Remove IACV from manifold
    2. Place IACV on top of gasket material (less than $4 auto parts store)
    3. Trace it out on gasket material making sure to mark the bolt holes
    4. Cut the material and put holes where the bolts are
    5. Place gasket between IACV and intake manifold and re install it
    6. Bleed coolant system
    If you've got an "up/down" idle problem, try cleaning out the Fast Thermo Idle Valve. On my H23 its under the throttle body and should be in the same location on your motor. Remove it and spray the inside of it with carb cleaner. Reinstall, bleed coolant system, and finally re-adjust yor idle.
