Results 1 to 11 of 11
Thread: H22 will not start. NO fuel?
    "...you say that because" redciv1's Avatar
    Default H22 will not start. NO fuel?
    H22 has been running fine then this morning the car would not start. Sounds like the car is not getting fuel. It is not fast spinning like the timing belt. Fuel pump is coming on. How do you tell if there is fuel going to the engine.
    Savannah
    easiest way is to either disconnect it at the fuel filter on the firewall or the hose that connects to the injector rail. Hope you figure it out!
    North Augusta, SC
    maybe it sounds like it isn't getting fuel cause your fuel tank is empty?
    jk
    anyways, good luck with this. hopefully its a cheap and easy fix for ya
    Back to being stock and slow
    Senior Member G.C's Avatar
    Forgot
    are you getting any spark? if your fuel pump is working i'm pretty sure you have fuel going to your engine. but check that too. if you have Fuel,Spark,Air=Car cranks.
    :idb:
    I actually asked the new owner if the tank had gas because I know people are getting crazy with stealing gas. How do you check for spark. Take a spark plug out and hold it close to the engine block? I don't remember.
    Quote Originally Posted by redciv1
    take one of your spark plug wires out, grab a screwdriver. MAKE SURE IT HAS A HANDLE ON IT. get someone else to try to start the car, while you have the metal tip of the screwdriver near the end of the wire, where it would touch the spark plug if in the motor. if you see the spark jump to the screwdriver, you have spark. hope that helps, and anyone help out if i missed something.
    I don't pull out... E=MC˛'s Avatar
    Where we like our sisters...
    my b18 was doing that the engine would turn over but it wouldnt fire. turned out to be my dizzy i got a new one and it fired right up
    So Fuel Pump, Grounds and Dizzy. I didn't change the Fuel Pump and I know I did not change the Dizzy either. Thanks. I gave him the link to this page and PMed him.
    JDM TYTE AnthonyF's Avatar
    Cumming
    So it is spinng REAL fast? Is it just spinning or do you hear ur car making compression?
    no compression=timing belt broke
    compression w/ fuel=crank angle sensor or something else electrical
    -Ant.
    The Carbon Fibered R6
    Senior Member WalkS's Avatar
    Middle Ga
    Main fuel relay acting up? it controls your fuel pump, check that. My Integra does that when the weather gets hot, it doesn't want to start..
    JJSPEC Racing
    Good info board. I appreciate the help.
