Results 1 to 14 of 14
Thread: Valve Lash Adjustment
    Default Valve Lash Adjustment
    well, its time that i adjust my valves...this is my 2nd honda and will be my first time doing a valve adjustment , ive bled the lifters in a sr20 before but never a honda...
    i have the basic idea , unscrew the lock nut...get out a feeler gauge and adjust it with a screwdriver until there is a little play in the feeler gauge...is there anything i should look out for?
    i know it cant be too tight or too loose , it has to be just right...what else?
    yea and each piston has to be at TDC before adjusting..
    Hwy 315
    Here's the best write up for this on the internet:
    http://www.c-speedracing.com/howto/v...alveadjust.php
    *edit - cylinders need to be TDC on the compression stroke when adjusting.
    -jonathan
    [/URL]
    Jesus Christ is my Savior
    thanks, i was trying to find the helms/fsm...repped
    Intake 0.15 - 0.19 mm (0.006 - 0.007 in)
    Exhaust 0.17 - 0.21 mm (0.007 - 0.008 in)
    piston 1 to dtc
    then your done rotate the crank 180 degrees
    then do 3,4, and 2
    remember when your done to torque them back done to 130ft.
    On B16 Gsr Type R I adjust mine 0.07 on intake an exhaust......bigger difference on the bottom end
    lock nuts to 130ftlbs..uhhh lol??
    edit- runs good
    Quote Originally Posted by Benefit
    edit- runs good
    yes 177 Nm (130 ft.lbs.)
    you are smoking crack. The flywheel bolts arent even 130 ft lbs
    130 ft lbs would shear that 10mm off.
    You might be thinking 130 in lbs
    wow corrected by the honda nissan lexus and all around import GOD woot.
    sarcasm for those who missed it.
    thankx for pointing that out didnt notice.
    im rechecking everything
    you have to do it in order 1-3-4-2 if it is louder then you got them to loose....if they was too tight they will pop threw the exhaust
    yea i redid it...quiet now but i think theres just ONE that could use a little more adjustment
    well you said 130 ft lbs TWICE
    what if someone read this and went an did it.
    Thats how bad info gets passed around, dont take it personally, it was a typo, i corrected you, no big deal.
