Results 41 to 63 of 63
Thread: fuel pump on a 92 teg
    Athens/ATL
    You neglected to mention the car is boosted.... what ECU program are you running?
    Default hey
    right now i got chrome but everything is fine with that but i cant get my injectors to fit in i know im not makin any sense but im tryin to
    SwiperNoSwiping!!
    Quote Originally Posted by tenn69
    which ones are you trying to fit? The 550cc RC ones?
    They should just kinda pop right in place....
    u remind me of a wigger !
    Default hey
    Quote Originally Posted by GM_TUNER
    there evo injectors an there not fittin in the clips
    SwiperNoSwiping!!
    on the wiring harness? Take the little metal paper clip part out of it, and just slide the plug onto the injector. It'll still work fine without the little retaining clip
    SwiperNoSwiping!!
    So, apparently its more than just a simple air/fuel/spark equation then, correct?
    correct because its gettin spark it ran fine last week an then my axel broke an the batt wire to the fuse box under the hood had messed up so i got an new fuse box hooked everything back up the way it was supossed to go
    Athens/ATL
    It may still be injectors, but being boosted brings in a whole new set of problems it can be.
    SwiperNoSwiping!!
    Well, i guess if it wont fit then maybe u cant/shouldnt use them
    Default oh
    is there a way to clean the injectors
    Athens/ATL
    Dip em in gas and wipe.
    Default hey
    thanks bro
    Athens/ATL
    thanks bro
    Do you see my sig?
    Do you see where it says "MY NAME IS EMILY DAMMIT"?
    Now tell me... why would you call someone named Emily "bro"?
    GAH.
    Default hey
    Do you see my sig?
    GAH.
    lol my bad i never really looked at it but thanks girl you cool as hell
    SwiperNoSwiping!!
    So does everything seem to be coming together for you now?
    Default hey
    im hoping so ima try to clean the injectors i just dont know whats going on if you try to start it with an keep pumping the gas it seems like it wants to stay started but just aint gettin enough gas
    Athens/ATL
    Just out of curiosity, how much gas is in your tank?
    SwiperNoSwiping!!
    LOL
    Default hey
    more then half a tank
    Athens/ATL
    I do try (on the cool as hell part).
    Clean your injectors, siphon your gas out, put in about a gallon of gas with a fuel treatment additive, and run it.. I was about to tell you to seafoam your whole system, but I'm pretty sure you're not supposed to seafoam turbo engines.
    Default hey
    lol ok well im just gotta take you an gm advice an do everything you to have said
