Results 1 to 14 of 14
Thread: Need help with spindle nut
    Aiken, SC
    Default Need help with spindle nut
    Ok, I'm still trying to get to my tranny to change my clutch. I finally got the ball joint issue solved. Now I've got another issue. I'm trying to get the spindle nut off. The driver's side came off fine, but the passenger side is messed up. Someone before me punched the locking part of the spindle nut in too far. And now I can't get it out. I've tryed a punch set, screwdriver and such but part of the metal is messed up and so I can't get anything wedged in there to pry it apart. Any suggestions?????
    Drive a 95' Integra GSR
    take a impact to it ...an break it off inside, once you get the nut off then you will be able to notch it out very easy then just buy you another pin later
    Aiken, SC
    Bad part is that I don't have an impact. Don't know if it makes a difference, this is on an Integra
    Scottish Scotsman's Avatar
    on the road to recovery
    get a good breaker bar and a really really long sissy bar to go over it , have someone hold the brakes real hard and put some serious a$$ into the breaker bar
    Quote Originally Posted by TheScotsman
    thats how i do it.
    thats how i do it.
    lol , we took a 13' piece of my dad's chain link fence and my buddy who is about 250lbs on the end of it , the sum ***** came right off
    Marietta, GA
    yep, what he said ^^^, gonna be a ***** if you don't have power tools. i've always been able to pry the bent part ot with something, a chisel, small screwdriver, anything with a thin flat end.
    E46 M3 Z0_o6's Avatar
    Suffolk, VA
    Snap-On XT7100
    i havent run across very much it can't break loose.
    Who knows?
    Aiken, SC
    Thanks guys. Tried holding the brakes down and using a torque wrench and breaker bar. but the nut is stripping now
    if the nut is stripping then your using the wrong socket its a 32mm
    Hamilton, GA
    impact is the best way to go
    Aiken, SC
    I'm using a 32mm socket.
    i did it 2 times today by hand took me all of of 5 minutes. keep tryin at it.
