Results 1 to 22 of 22
Thread: How much in labor for Headgasket and piston rings??
    SwiperNoSwiping!!
    Question How much in labor for Headgasket and piston rings??
    I've got the parts, all i need is someone to replace my stuff cuz my motor smokes like a mofo when i push it really hard or when its cold and its only at 135k miles. (WHITE smoke not black...)
    Im talkin about a '90 DB1, B18A1 motor in it. So, on average, can someone estimate to me how much would that cost??
    u remind me of a wigger !
    if your replacing piston rings you might as well do bearings
    LAWRENCEVILLE
    it would be cheaper to just buy a long block from me!
    Hella stock member!
    SwiperNoSwiping!!
    labor only plz!
    to replace the RINGS< you have to drop the pan an pull the head.
    you might as well replace the bearings while you are at it.
    THe do rings and a headgasket figure $750-1000 in LABOR only.
    10-15 hours from a shop.
    Silversol is right, you are better off buying a longblock.
    And if your motor smokes from OIL just re-ringing it may not fix the problem if the bore is out of round
    if youre doing rings you might as well rebuild
    Stang Mod slostang's Avatar
    Southside
    Quote Originally Posted by mwilson
    I think everyone just said that.
    Athens/ATL
    Quote Originally Posted by slovic-fcc
    no, they said to replace, not rebuild. L2Read. :P
    OP - sounds like upgrade time to me!
    SwiperNoSwiping!!
    oooo, ok.....so, sounds like its time for an engine swap? Only because it would be cheaper??
    Athens/ATL
    Quote Originally Posted by GM_TUNER
    It would probably cost about the same, but would be much less of a headache.
    Think about it this way...
    REBUILD:
    1. Pull engine.
    2. Tear down engine.
    3. Build, build, build, build.
    4. Replace engine.
    5. Pray.
    REPLACE:
    1. Pull engine.
    2. Replace engine.
    3. Pray.
    More chances to mess something up on a rebuild (especially if you're DIY'ing it). Messed up rebuild = you're in the same place you started from, but out $1000.
    You can pick up a B20B/B20Z or a B18B pretty cheap. Smack a GSR head on there (if you wish) and call it a day.
    If you are doing a Re ring, bearings you dont have to pull the engine out
    REBUILD:
    1. Pull engine.
    4. Replace engine.
    5. Pray.
    REPLACE:
    1. Pull engine.
    2. Replace engine.
    3. Pray.
    L'ville
    you burning oil?
    SwiperNoSwiping!!
    ^^^^^yea i think so.
    L'ville
    call joel and get him to build you another one of those beautiful B18B's
    SwiperNoSwiping!!
    Quote Originally Posted by stygiosracing
    yea, he said he's gonna call me about it later. I sent him a message earlier.
    Whats the diff between b18B vs. B18a....?? is it vtec?
    lol, not hatin on vtec, but i sorta dont want it. gonna be track racing once its fully built.
    Athens/ATL
    I believe both are non VTEC. I know the B18B is non-VTEC. Not sure about B18a. Google it, n00b.
    L'ville
    both are non-vtec. the b18b just has a slightly higher compression ratio and a slightly different intake cam. what year is your DB?
    GetItFixItFlipIt Timinater's Avatar
    pm'ed
    C.r.E.a.M MistaCee's Avatar
    Work
    B18b I believe is the 94-2000 Integra engines that have bigger intake manifold and different wire harnesses.
    b18b are rated 142whp, and b18a are 140whp.....same shiit all i can say lol
    North Augusta, SC
    ^^^ Phantom said "rebuild" not "re-ring"
    Back to being stock and slow
    North Augusta, SC
    Like posted before, replacing rings may not fix all your problems and may actually cause you more headache than it would be to replace it, have a more reliable motor, and save money...
