Originally Posted by
green91
Remove the entire speed sensor where the cable slides into the trans and you should be able to get the cable out with it out of the car.
Use the cable SI trans to make it easy on yourself. You will need to use the cable speedo in the trans anyway unless u wanna convert clusters etc for electronic vss.
the d16z6 will bolt in very easily with the a6 cable trans, you will need to modify the driver side timing cover and use the ORIGINAL a6 engine mount on that side. the other 3 mounts are on the transmission. use the stock SI harness on the d16z6.
