Thread: Maintenance Bolt question on H22
    "...you say that because" redciv1's Avatar
    Default Maintenance Bolt question on H22
    I cleaned out my PM's and deleted some. Does anybody know if oil comes out of the Maintenace bolt hole on the backside of the engine. This is the hole use to line up the rear balance belt. I drove less than 80 miles Sunday and checked the oil yesterday and it was nearly empty. Also, what size bolt? Pleez.
    on the side of the tranny is a bolt in the tranny. look for the lowest bolt on the that isnt 1 of its casing bolts. thats the drain bolt. up a lil higher is another 1 a lil bigger in size that the fill while. go to the top pull the speed sensor out fill with oil from there. when fliud runsout of the full whole your done.
