Thread: tranny fluid level???
    2.2 CL
    Default tranny fluid level???
    how do i check it on a 95 civic?
    Newbie Photodude RBS's Avatar
    All Over U S A
    with your car on level ground, open the upper tranny fill bolt ( a 17mm ) and if a little oozes out then your fine. if it doesnt, add a little more till it does
    Correct if you need to add some its easier to install fluid by the speed sensor if your not jacked up the car already , just remove the 17mm upper fill plug,an one 10mm bolt on the speed sensor, twist the sensor left to right to losen it, then pull straight out, reverse to install it back, long skinny funel an pour the fluid in until it runs out of the upper fill plug hole. then install the fill plug an your done....hope we helped
    Quote Originally Posted by 1siccEJ2
    2.2 CL
    Quote Originally Posted by JoshuaASE
    thanks... it was bone dry
