Thread: 88 transmision on a 95 z6 big problems HELP PLEASE
    Senior Member | IA Veteran Mad Mike's Avatar
    Gainesville
    Default 88 transmision on a 95 z6 big problems HELP PLEASE
    Well I have a 90 crx and I swapped a 95 z6 into it and used my 90 transmission.
    Blew the trans last week. I drove 80miles and picked up a transmission today.
    I got home and started to prep it for the reinstall.
    I stopped and looked at the 90 trans and found that the new trans was different.
    its a 88 21 spline and I have a brand new 90 20 spline clutch and lightweight flywheel.
    Can I just buy a 88 pressure plate and clutch disk and use my 90 flywheel?
    or do I just need to buy a hole 88 setup clutch pressure plate and flywheel?
    Please Help I really need this car running ASAP thanks
    Mountain man green91's Avatar
    Dahlonega, Ga
    EDIT: sorry im wrong, you will need an 88 flywheel & clutch. the spline count on the disc is different and the pp is smaller.
    Gainesville
    ok with some resurch I found that I can use the 86-89 2.0L accord clutch disk with my 90 flywheel and pressure plate. Its 212MM(90 clutch is the same) and 21 spline(88 transmission is the same).
    I posted in your other thread yo.
    Gainesville
    Default NEW Q????
    Are the axles the same between the 88-90 crx?
    Edit: N/M there the same. Looked them up at autozone.com
