Results 1 to 18 of 18
Thread: engine knock or exhaust gasket?
    Default engine knock or exhaust gasket?
    i have a z6....where the factory header seperates theres two round gaskets, one has a gap in it about 1/4 inch....
    i her the knoock coming from the bottom/front of the block(only knocks between 500-2500k rpm...then goes away....
    no change in performance although i have no power after 4900k rpm...just makes noise....still gets 30mpg
    ....knock or gasket....im gonna change the gasket but wonderin opinions...
    also if its a knock will just new bearings fix the problem or should just grb another motor....
    YEAH! bRiAnMcIvIcS's Avatar
    Douglasville
    If its knocking get a new motor. Is it an accord? If so just swap in an h22.
    Boost under slow construction...
    Mountain man green91's Avatar
    Dahlonega, Ga
    its a z6 so its obviously not an accord. seems like a dumb question to me, go ahead and replace the gasket first, a severe leak can sound like a knock at times. if the engine is knocking you're much better off replacing at least the short block since it seems you aren't very literate as far as engine rebuilding
    DUH-KYOO-LUHHH
    Quote Originally Posted by green91
    ive never heard an exhaust leak that sounded like a knock before. usually they make 2 different noises.
    but based on the OP, he knows his gasket has a huge hole. that would mean its most likely the gasket. replace the gasket and if it still makes noise, you need a motor.
    correct, havent built an engine myself yet.....was just wonderin if a header/exhaust leak could sound like a knock....and the noise goes away above 25k rpm so that made me ify on what the prob is...
    Douglasville
    Well his name is dumped accord, i wasnt really payin attention to what engine he had. Whoops! Good eye green 91. haha. If you replace the motor get a dohc.
    DUH-KYOO-LUHHH
    could it be your lifters? change your oil and see if it goes away
    Quote Originally Posted by jesse4846
    def coming from down low.....oil is 1600 miles old
    Quote Originally Posted by bRiAnMcIvIcS
    accord sold.....thinkin about ls or gsr but i go back down south to pick up...
    gonna go get the gasket today and put in tomorrow....
    Dahlonega, Ga
    I have heard an extreme leak (basically open dp) that did sound like it had a knock but its the one time that i have heard it.
    95 teggy for parts DaRussian's Avatar
    Douglasville
    Quote Originally Posted by dumpdaccord
    I had the same problem with a LS motor and the problem was my timing was off by like a tooth or two. it did the same thing, it had a knocking sound on low rpms and it did not have no power... i would be flooring it and i would be redlining it but it was really slow.
    VQ Power ------- SHIFT_W.O.T <br>
    03 Maxima 6spd VLSD -- 1/4 mile -- 14.12 @ 96.3
    92 eg Hatch b20vtec -- 1/4 mile -- 13.6
    Originally Posted by MMBmomoney
    i changed the vtec solenoid and nothing changed. in another post i saw "vtec fluid" where is that located and how do i check it?
    Quote Originally Posted by DaRussian
    this is interesting... have to look into this....
    DUH-KYOO-LUHHH
    how many miles are on the motor? sometimes even on 500 mile oil they will click, and ive heard some nasty lifters before. also, did you replace the gasket yet?
    Toyota Tech
    Dec 2003
    Claxton, GA
    2010 Scion xB
    yep even happend with my b16 that way fixed the timing and changed my oil with the lucas oil addictive its so thick its like honey and it freakin works great!
    Good luck
    Quote Originally Posted by Gutling
    260k mi...was told its 180kish...but im guessin its prolly 260k mi...
    Toyota Tech
    Dec 2003
    Claxton, GA
    lol yea... pretty sure you need a engine.
    2010 Scion xB
    ive had over 10 hondas with 150k mi plus and still run strong....mileage doesnt say much.....
    Toyota Tech
    Dec 2003
    Claxton, GA
    true, but knocking sure says a lot lol
    2010 Scion xB
