Thread: Cable Clutch Question
    Default Cable Clutch Question
    Was wondering if anyone has ever done this before, use a used oem pressure plate on a new stg 1 clutch disk. Will it be a problem or no...?
    ASE TECH.... wrekonize's Avatar
    SOUTHSIDE
    ive done it...it works
    Certified Gearhead Pavlo's Avatar
    Alpharetta
    It will work, it will be like stock though. Higher stages clutches hold power more due to the fact that the pressure plate has more clamping power. So all you'll have is a stock clutch with pretty much a stock disc. For instace, exedy stage 2 is a stock set-up with (I think) 15% more clamping power.
    Representing VWs.
