Results 1 to 12 of 12
Thread: 99 Civic Ex Trouble Getting Into Gears
    EM1 Crew Member
    Default 99 Civic Ex Trouble Getting Into Gears
    I'm noticing dificulty getting into my gears. I can crank the car in reverse or first gear but as soon as a pop it out of that gear and try to put it into another it won't go into another gear.
    So i'd have to turn off the car and place it in 1st, than crank the car back on and as soon as I get moving a little bit I can shift to my other gears just fine. There is no grinding while in any of the gears and I don't feel the clutch slipping.
    I could drive the car fine for a while but after the car parks for a while and I start it up the same situation goes on. Any idea on what it could be? Appreciate any help!
    1999 Honda Civic EM1 FBP (Current)
    1999 Honda Civic Ex VSM (sold)
    1997 Honda Civic DX MR (Sold)
    H-T EM1 Crew Member
    i had the same problem a while back.....
    mine turned out to be clutch slave cylinder under the pedal...
    superduper LLLLLLLLL
    bring it to vuong's garage in gwinnett.
    his phone number is in my sig
    Certified Gearhead Nissangeek's Avatar
    Smyrna
    Synchros maybe? If its a hydro tranny check your clutch fluid level. That happenend to my old Miata and all it needed was more fluid.
    Afghan Goober! TheChosenOne's Avatar
    my momma's house
    Quote Originally Posted by Nissangeek
    Prolly the fluid. My tranny was getting really hard to put into gears, and I was low on fluid. I flushed and filled it, problem solved.
    Trend settin'
    your pressure plate is bent aka needs a new clutch
    or
    you have air in your clutch system, bleed it
    Custom Tuning By Daniel Willie.
    Parts, Fabrication, Race Car Prep
    770-319-9605 or [email protected]
    Scottish Scotsman's Avatar
    on the road to recovery
    Quote Originally Posted by Batlground
    or
    i would highly reccomend listenin to this guy
    Senior Member khaxnguyen's Avatar
    clayton county
    ^^ lol @ you
    I give out reps....
    Look into your clutch fluid see if it is low, if its almost gone, you got a leak, most likely its either the clutch master cylinder, or Slave on the tranny, I would tell you from my line of work I reccomend, you replacing both at the same time, an then bleed it out, its a pain to do if your doing it by hand, BUT if your fluid is fine an not low at all, you wouldnt have air in it, ONLY time you get air in them, is if you broke the lines loose at one time, or have a leak, if the fluid is full, then you most likey have a clutch issue, need to take the tranny out to check it, thanks Joshua,
    EM1 Crew Member
    appreciate the help...i'll check the fluid.. i was thinking its the clutch slave cynlinder too or possibly the clutch...
    H-T EM1 Crew Member
    You look like a clutch.
    Norcross
    Quote Originally Posted by AirBrcak
    hahahahahhaha pwned!:idb:
