Results 1 to 6 of 6
Thread: EF engine code
    Senior Member mikesEK's Avatar
    over yonder
    Default EF engine code
    1988 "EF" sedan
    flashes 16 & 17 ,,,and the CEL come on from time to time
    but car seems to run fine and dosn't eat much gas
    PawnShopMike
    I miss-spell big words freeqwentlee thanks Dekalb Co skhool systems
    Your moms house
    Fuel injector and speed sensor. Did you clear the codes?
    over yonder
    I believe speedo cable is not connected (cuz the cluster never moves from 0mph)
    and how do I reset/clear the codes?? thanks in advance
    PawnShopMike
    Your moms house
    Pull the ecu/back up fuse under the dash. Leave it out for 1 minute. hat sould clear the codes.
    over yonder
    taking the negative terminal off the battery for a minute would do the same thing yes or no????
    PawnShopMike
    Jonesboro/Stockbridge
    Quote Originally Posted by mikesEK
    you would have to take the positive off...
