Results 1 to 7 of 7
Thread: 88 "EF" alternator possibly bad
    Senior Member mikesEK's Avatar
    over yonder
    Default 88 "EF" alternator possibly bad
    PROBLEM SOLVED!!!!PLEASE DELETE!!!
    1988 civic .............when car is revved up around 4500 5000rpm the battery light comes on ,I assumed the alternator is going bad and dropping in voltage ,but i hooked up a multi-meter and found out it when I rev up the car the voltage jumps to 17-18-19volts
    my question is ..is there an external voltage regulator ((i don't think there is))that needs to be replaced or does the alt need to be replaced
    next question....((i have 2or3 alternators lying around from d-series "EK" motors)) will "EK" alt work on the "EF" I figured they might swap because they're both D-series
    Thanks in advanced guys...later
    PawnShopMike
    I miss-spell big words freeqwentlee thanks Dekalb Co skhool systems
    E46 M3 Z0_o6's Avatar
    Suffolk, VA
    alternator has an internal voltage regulator, replace the whole thing.
    Who knows?
    over yonder
    Quote Originally Posted by hondabuilder
    have you ever seen one put out MORE voltage than it should????
    PawnShopMike
    gwinnett
    ^^ No, usually 14.
    Your moms house
    You can change the voltage regulator. All d series alternators are the same but the voltage regulators are different. You can use a ek alternator but you have to change out the regulator,but yours is bad.
    over yonder
    ummm.....is that a yea or a nea
    PawnShopMike
    Your moms house
    Well the alternater will work from a ek but you have to change out the regulator. The one you have in the ef alternator is bad though. You need another regulator.
