Results 41 to 64 of 64
Thread: RWD guys, gear ratio question
  1. #41
    C7 On_Her_Face's Avatar
    Duluth
    haha. well the Saleen is just a GT unless it actually has a blower. so your saying the Saleen has a 3.73 rear end upgrade?
    yes all saleens have a 3.73, sorry i forgot to add that in there
  2. #42
    JDM TYTE AnthonyF's Avatar
    Cumming
    Quote Originally Posted by LS2_KID
    ok fantastic. thats helps me out with my decision a little more. I'll prob go 4.10 then. thanks billythekid310.... was it 310? i dont remember.
    The Carbon Fibered R6
  3. #43
    Duluth
    yes sir
  4. #44
    Cumming
    ~i has good memoriez~
  5. #45
    LAWRENCEVILLE
    i had a 410 in my 02 gt it was a bit over kill i would do the 390
    Hella stock member!
  6. #46
    Cumming
    Quote Originally Posted by silversol
    can u elaborate? what speed was over kill? also, my trans is different than yours. mine is more economy designed
  7. #47
    ASC is for fools Blitanicle99's Avatar
    Woodstock
    I would go 3.73s to 3.90s. 4.10s is overkill with your set up. Find another stang with the gears you want and get him to take you for a ride to see if you like it or not.
    Honda RC51 SP1
    Yoshi RS-3 Cans
    520 Conversion
    Clip Ons
    Race Tech Fork Kit
  8. #48
    LAWRENCEVILLE
    it was not really that bad it just killed my gas mileage. My buddy put 3.90 in his and did not affect his as much but with your trans you should be ok.
    Hella stock member!
  9. #49
    Cumming
    Quote Originally Posted by Blitanicle99
    i dont hang out with mustang owners. only 2 are Sicstang and WHAT_LAG both have Silver Cobras. lol. mustang owners are typically dìckheads.
  10. #50
    i wouldnt do 4.1, 3.73's was a decent compromise for me, decent out the hole and decent at cruising down the interstate.
  11. #51
    Cumming
    yea...but i want low ET's and I WANT cover of Modified Mustangs Magazine. I will do it.
  12. #52
    so make more powa lol. prob solved
  13. #53
    Cumming
    i was SUPPOSED to be making right at 400 last time but the tuner suked balls and my motor blew up (again). So, this time around...I SHOULD be above 400 but remember, my car isnt a miata..i weigh 3600lbs
  14. #54
    Toyota Tech
    Dec 2003
    Claxton, GA
    4.10s 4.10s 4.10s if you dont you will always regret it and wonder what if lol
    2010 Scion xB
  15. #55
    Cumming
    FUK!!! all of you with your different input........i will ponder this question for many moon.
  16. #56
    Quote Originally Posted by Gutling
    you will always wonder what if i really had worse gas mileage and turned higher rpms constantly
  17. #57
    Cumming
    I hate u redrum. lolol. runs and cries cus my head hurts
  18. #58
    Toyota Tech
    Dec 2003
    Claxton, GA
    how close is your trans to the new edge gts? my friend with the 4.10s we make the trip from school here in statesboro to atl (about 31/2-4hrs) every other weekend and the gas mileage is not that bad. ill ride with him today and see what his rpm is around 70ish. lol get a 6spd and convert it to fit :P
    2010 Scion xB
  19. #59
    I hate drifting Big Baller's Avatar
    Nov 2003
    In the Fucking A
    Man up and put the 4.10s in it
    Quote Originally Posted by Slowwrx
    I fucked İhris's mom
  20. #60
    Cumming
    ^fukkin peer pressure.
  21. #61
    Turbo-Wired
    East Cobb
    TM40: Have you considered actually changing your 5th gear in the gearbox and running a 410/411? If you can make it down your usual strip only using 1st through 4th, it's the perfect compromise. Nice low RPMs on the freeway and the same ET's you'd be getting with a 410 rear end and your current tranny. I've never looked into what it'd take to swap a mustang gear out, but it can't be that difficult in comparison to stroking/boring engines, FI, etc. Now, I dunno if you usually do 1/8ths or 1/4ths with the stang, and that kinda makes a difference. I also don't know whether or not you'd reasonably be able to only use 1 to 4 on the 1320 with the new rear end. I have not thoroughly researched this, but it's an idea that literally gives you the best of both worlds. If your 5th is just a mild overdrive (like 0.90 then maybe go with the GT's 6th gear cog if it fits (It may not, I dunno) Which would probably be a 0.85 or 0.80). Guys who do a (I know, I'm talking about Hondas, but the same idea applies) GSR motor in Civics often have to struggle with what tranny to use (B16 Tranny or the GSR Tranny or an LS Tranny) for the exact same reasons you're debating now. This kind of compromise has worked for them, and push comes to shove, if you wanted to do it and couldn't find a replacement, you might be able to have a machineshop actually make you one that fits as a replacement.
    Just a thought.
    And yeah, I know you said RWD guys only, but hey...I drive with the rear wheels too!
    *hides his transaxle and front driveshafts*
  22. #62
    Cumming
    Ive done plenty of drag passes but Im not maxing out or coming near maxing out 4th gear crossing the line. And my tranny is the v6 tranny. They dont make any parts for mine.
    but i appreciate the help and info. +8
  23. #63
    Senior Member onebadgt's Avatar
    i just noticed this thread i should be able to help you, 3.90 would not be to much gear for you, ive been running 3.90 in my car for about 5000 moiles and i love them except they would be much better at your pwr level than mine. you can still go 120 in 4th gear and i can cruise at 75 at 2800rpms and get 23mpg. so saying there not streetable would be wrong i drive 300miles a week with them. you will barely even notice the diff if you go to a 3.73. by the way trymy, check your pms
    o n if you see me out i would be more than happy to take you for a ride so you can see the diff and shiftpoints of the 3.90>3.55
    2006 mustang gt
    gears
    bolt-ons
  24. #64
    Cumming
    appreciate the help mang. PM'd u back.
