Thread: ef ignition.....bad
    Senior Member mikesEK's Avatar
    over yonder
    Default ef ignition.....bad
    I have a 88 4-door EF 5speed ,,,and i went to crank her up this morning and the lights heater radio ect ect come on but if feels kinda clunky when you turn the key (and you know how the key will push back ,like it spring loaded) well it dosnt do that any more
    My question is
    #1..can I replace the ingnition and keep the same key
    #2..does any body got one they can sell me?
    #3..what would one cost at the parts store approxitmatly
    thanks guys....mike 770-309-3487
    PawnShopMike
    I miss-spell big words freeqwentlee thanks Dekalb Co skhool systems
    over yonder
    nothing.....c'mon guys
    PawnShopMike
    Certified Gearhead 1flysi's Avatar
    Your moms house
    Just went through this on my buddies crx. The spring is in the ignition switch and not the key cylinder. The ignition switch and the key cylinder are around 50 a peice from advanced auto. You can take the igniton switch off from the back of the cylinder and determine whether it is the ignition swith or the cylinder.
    If you take the column cover off(three screws and a retaining ring) you can access the ignition. he ignition switch is held on with two phillips head 7 mm screws. take them out and remove the ign switch. You should be able to insert a flat head into the switch and crank it up. If that works fine than it is your cylinder.
    1.5T AnTi-PooN's Avatar
    L'villE
    lol... nothing more to say
    over yonder
    Quote Originally Posted by 1flysi
    wow...thanks ...thats the repsonse I was looking for ,now I'm almost positive it the key/cylinder ,,,can I replace this and keep my key so the doors and ingnition are the same
    PawnShopMike
    over yonder
    never mind (to the last post) you said the spring loaded part is in the IGNITION and NOT the cylinder.....OK imma take it apart and see whats up,,,seems like the ignitions is going to be bad and not the cylinder,,which works out considering I really don't wont to have two have separate keys for the door and ignition
    PawnShopMike
