Results 1 to 13 of 13
Thread: integra problems
    Default integra problems
    i have a 94 teg ls it will turn over but will not get spark or fuel ive changed computer harness and distributor checked fuses main relay grounds on motor and tranny i dont know what else it could be any help is greatly apreciated you can even buy it lol
    Oct 2003
    Fuses and/ or relays?
    ive checked the main relay but i dont know what else controls both fuel and fire
    Out the game again!!
    southside of the border
    might be rotor button or distributor cap or both
    Soon!!
    4do' not wifey car.. JDMirza's Avatar
    gwinnett
    Did you check if your plugs for the coil is connected.
    Also.
    Check to see that the little carbon contact for the center terminal is in place. Without that, you can have the spark but it won't go to any of the plug wires.
    Certified Gearhead 1flysi's Avatar
    Your moms house
    I doubt it but it could be a ignition switch. Are you sure the main relay was good?
    yea it is good we had the swap in a civic and it ran for like fifteen mins then quit so we tried the main relay new fuel pump injectors then we realied it wasnt getting fire either so i put it in my integra and it ran for fifteen mins or so and quit since ive changed computer harness and distributor i just dont know
    Your moms house
    Are you getting power to the dash and ecu? Does the cel come on when you turn the key on?
    yeah it does but it is a constant light it doesnt flash when i jump the plug
    help anyone
    Southside
    So did you check the fuses underneath the hood and see the the ECU fuse, located in the back on the far left, should be a 20. Is that fuse blown?
    chamblee
    I had some problem with integra and just put in a MSD cap, wires,capaciter and coil.
    no more problems with the car.
    M.O.B inutero93's Avatar
    valdosta ga
    i had the same kind of problem in my hatch . the yellow looking filter bag fell off the fuel pump . it took me forever to figure it out because my fuel pump was comming on but no fuel ..
