Results 1 to 24 of 24
Thread: Oil change Question
    한 국
    Default Oil change Question
    i have a DC2/GSR and im planning on doing an oil change myself. does anyone kno how many quarts i need to do the oil change? thanks
    You need 4.
    한 국
    damn dats it? i thought it be like 6
    Quote Originally Posted by eYezs1ck
    Nope just 4, but I get 5 just incase Im low later on the road.
    Your Moms Moderattor
    pleasant hill
    I thought it was 4.5
    한 국
    maybe 4.5 thanks
    Should be exactly 4.
    SOHC my DOHC Meso Teggy's Avatar
    Atl
    non vtec 4qts vtec 4.2-4.5qts
    Don't forget a new oil drain plug washer, an dont use FRAM OIL filters
    Belview Insane Asylum
    6?!
    My 02 4Runner takes 6. GSR's take like 4.5 if I remember correctly.
    AWD OH MY KPowerEP3's Avatar
    Ellenwood
    I always did 1/2 quart or w/e in the filter [ or as much as it will hold ] and the 4 in through the fill cap.
    bavarian motorsports FTW!
    where ever theres food
    i prime the filter so i dont do a dry start and leave the plug out and pour fresh oil in until it starts coming out clear.
    "The M3 engine does not develop it's power ... it is simply present in an overwhelming quantity at any time. "
    AutoZeitung 1992
    San antonio 210
    4Q.. i think it recomends 5w30 or 10w30
    한 국
    thanks guys i just used the mobil 1 5w30 with mobil 1 oil filter
    ATL, GA
    Good choice!!!
    Straight up JDM!
    If I were you, I'd use Castrol Synthetic and Fram Oil Filters/or K&N oil filters...This is better choice...
    ATL, GA
    Castrol Synthetic, in my opinion along with others burns off faster than other oils. As for the oil filters, there are researches online saying farm's filter has worst filtering materials. My question for you, jdm_91crx, is you either use a 3USD filter or a 12USD filter?
    Straight up JDM!
    Quote Originally Posted by chituntang
    I use 12USD filter...and Castrol is better for vehicles with higher mileage...or use Valvoline Synthetic oils (I use to use Valvoline but switched to Castrol)
    JDM TYTE AnthonyF's Avatar
    Cumming
    typically its like 4 cyl, 4 qts, 6 cyl 6 quarts. not saying it is like that all the time. 5.7L Chevys 5-6 qts, 5.7L hemis- 8 qts.
    The Carbon Fibered R6
    E46 M3 Z0_o6's Avatar
    Suffolk, VA
    you people are idiots
    Who knows?
    i wish my 6 cyl took 6 qts of oil. Damn 8 qts cost too much
    I drive a dodge stratus 98strat's Avatar
    Norcross
    My 6 cyl only takes 4.5
    Cumming
    Quote Originally Posted by 98strat
    ur 6 cyl is the size of new honda's 4 cyl.
