It will give you the sound, but it could also blow your motor. The problem with a lot of the CAI and Short rams is that they change the diameter of the Mass Air Sensor housing and the result is that if it goes larger, you are pumping more air into the engine than it thinks...this results in possible lean conditions and blown engines. Without engine management of some sort or tuning specifically for the intake, be careful. Or buy a decent one that is the same diameter as your stock MAF housing.
