Results 1 to 13 of 13
Thread: Stupid battery question...
    Jonesboro/Stockbridge
    Default Stupid battery question...
    Okay, I got my alternator checked and I charged my battery, but for some reason my stupid battery light is still on. And I think it might die on me again like it did before because it got to the point where I had to jump the car and if I turned the lights on when I disconnected the jumper cables, the car turned off...
    Any suggestions on what the heck is wrong?
    San antonio 210
    bad connection some where..
    most likely a bad ground or like cactus said bad connection or wire. On my crx there was a break in the wire that goes from the alt. to the main fuse box so I ran a wire between the two points till I had time to pull the harness apart.
    good luck
    I'm pretty sure my grounds are on good, I double checked those...but I'll triple check tomorrow. Would wiring a fan switch directly to my battery effect this? But it showed the light before I even wired the switch...
    So...how would I check for bad connections? I don't want to just check EVERY wire...thats a lot of wires...
    I disconnected the wire that connects the alt. to the main fuse box and checked it with a volt meter and thats how I found mine. I got lucky, just take your time and check all the connections that you can find. A wire could have broken out of the connector or something like that. Electrical issues suck
    Oct 2003
    I would have the wire double checked by someone else to confirm that the alternator is ok. It needs to be putting out at least 13 volts or better without a load. Check all your connections at or near the alternator
    Not blowin up now MattB's Avatar
    Columbus, Ga
    bad connection or ground sounds like to me. have you put a volt meter on the battery while its running to see if its charging at all? should change the voltage reading once the car starts(an increase obviously)
    Hmm, I had it checked by AutoZone when I took it out and they said it was good. I wonder if the wire to my alternator is bad. I need a volt meter...sigh. Not having the right tools sucks!
    Columbus, Ga
    get one from walmart, usually under 20 bucks or borrow one
    San antonio 210
    Quote Originally Posted by Mad Mike
    listen to mike. this boys a wizz kid at electronics and wires
    not really I just mess around with this stuff and learn as I go.
    umm is your belt tight?
    Quote Originally Posted by drmcivicsi
    Its pretty darn tight...How tight is it supposed to be. If I poke at it with my finger it moves less than half an inch I suppose. Thinking I might need a new belt maybe? Maybe this one has been stretched out?
