Results 1 to 5 of 5
Thread: A Problem starting the 94 Integra LS sometimes
    Default A Problem starting the 94 Integra LS sometimes
    I seem to have a problem starting the 94 Integra sometimes. I turn the ignition to wait for the fuel pump to turn on, but sometimes the pump doesnt turn on. I think the pump might be bad or on its way to failing. I have to turn the ignition on and off several times to get the pump to turn on. That happens about 50 % of the time while the other times it cranks right up. The pump doesnt turn on sometimes when the motor is cold and sometimes when the motor has warmed up.. Any ideas guys?
    Your Moms Moderattor
    pleasant hill
    change the pump, or the relay,or both. not hard.
    middle ga
    i would bet main relay..its a very common problem
    Sep 2003
    Quote Originally Posted by japan4racing
    +1
    Sep 2003
    Here check out this site on how to fix the main relay if that's your problem:
    http://techauto.tripod.com/mainrelay.htm
    This is what I did to mine, and it worked flawlessly after that.
