Results 1 to 11 of 11
Thread: S10 question...
    FTP!! GSXR dude 95civictypeR's Avatar
    Henry
    Exclamation S10 question...
    I have a 1999 S-10 reg. cab, 2.2L how hard it is to put a 4.3L in it? Will it bolt right up? or what? thanks Seth...
    Not blowin up now MattB's Avatar
    Columbus, Ga
    wouldnt imagine it would be too hard as it came as a factory option. two wheel drive or 4 wheel drive?
    Henry
    two wheel drive.. and also anyone know if i have a 4.3L would the 2.2L tranny hook up to the engine? or if it did would it be worth the extra money and time to get the 4.3L tranny?
    free the twins
    gainesville
    the 2.2 trans will not bolt up to the 4.3, if you use a carb on the 4.3 it is not that hard of a swap if not you will need the harness. a trans off a 350 will bolt up to the 4.3 and you will have to get a drive shaft lengthened of find a 4.3 truck to get one from. you will also need a set of motor mounts
    Henry
    alrighty... do you think its worth all the trouble.. or not?
    I do, I love my 4.3. Shit is a beast son.
    free the twins
    gainesville
    if you are going to go through the trouble to put a 4.3 in you should go a head and put a 350 in it. but i would def. get rid of the 2.2
    ^^^Truth
    Henry
    ok.. but i want to supercharge the s10 with whatever engine i have in there which one will be better with one? the 4.3L or the 350? and what is cheaper? thanks.. Seth
    Henry
    well yesterday i got a 305 w/ tranny from a friend for 200 i heard there was a way i could put a 350 head on it. is that true? and maybe theres someone that knows all what i need to do to make this a successful swap.. Thanks Seth
    Where Am I
    350 heads on a 305 really won't do anything I think 305-HO heads would probably be better then 350 but that really not worth doing unless u just have them sitting around or something, I'm pretty sure to swap that all u need are the motor mount plates that they sell for like $65 for the price their not even worth making them, and depending on weather your going fuel injection or carburation their still is going to be a lot of work cause yours is only the 2.2L, if your truck was a 4.3 everything bolts right up to the V8's, Their is so many things on the internet about swaping V8's in these trucks just do your research cause I gaurantee u someone has already tried it on an S10.......
