Results 41 to 80 of 100
Thread: problems problems problems wtF.. !! HELP
  1. #41
    IA Member wanksta's Avatar
    powder springs, GA
    sorry lsextereme. i was try to save you some trouble but it has turned into a pissing contest.
  2. #42
    Broke sullen's Avatar
    Acworth
    brits always measured in inches.... and common way of measuring .062" btdc is to notch a dowel long enough to reach the piston crown and then extend out above the valve cover. move the engine to TDC #1. then mark where the dowel is in relation to valve cover vertically(z axis) and move towards the top of the dowel .062", mark there again. find tdc again with the dowel, back up plenty, move toward tdc again to get rid of the valve lash, slowly bump to .062 btdc, set the ignition. boom, its for distributor only. i dont know if you can do this the distributorless ignition.
  3. #43
    Acworth
    easy enough to understand.
  4. #44
    Douglasville
    Quote Originally Posted by wanksta
    Welcome to IA.... That Shit happens in every Thread... ... You will see alot more of it too !!... .. Bunch of Master Techs on Here... ... Later !!
  5. #45
    Acworth
    i is not a master tech, just a tinkerer and restorer. wish i had the master tech certs, i'd be bankin
  6. #46
    Douglasville
    Quote Originally Posted by sullen
    Thats the Same Concept when Degreeing Cams.... Execpt you don't have a Wheel.... :boobies: ... Later !!
  7. #47
    Mountain man green91's Avatar
    Dahlonega, Ga
    how many people are truly master techs and have the credentials to prove it though?
  8. #48
    Acworth
    prolly not that many on here.
  9. #49
    Acworth
    Quote Originally Posted by 1civic
    cool, i didnt know, i just know how to figure lobe/lift/rar/duration/etc...
  10. #50
    Dahlonega, Ga
    ive always wondered, i dont widely publicize my credentials but im proud to say i am a master. im just curious how many others are professional technicians on here.
  11. #51
    Acworth
    why'd you get banned?
  12. #52
    powder springs, GA
    that is cool. ive never seen that, learned something today.
  13. #53
    Dahlonega, Ga
    im not banned.
  14. #54
    Acworth
    cool cool, i can try to get a good picture of some of our english motorcycle manuals if you want proof... just have to give me some time to go find them in the garages.
  15. #55
    Banned lsxtreme's Avatar
    http://s32.photobucket.com/albums/d7...t=401d637c.flv
    http://s32.photobucket.com/albums/d7...t=d35238e8.flv
    1st video is showing 3rd gear petal to the metal on a str8 way..
    2nd video is 2nd gear.. climbing a hill..
    i was trying to get a clip of the noise but i can hear it .. but i dont think the clip is catching ..
  16. #56
    Acworth
    Quote Originally Posted by green91
    im not banned.
    oh, i thought you were banned cause it says banned under your name
  17. #57
    Douglasville
    I can't think of One Performance shop that Has a Master Tech in GA. Most never take the Time to get ASE Cert. Not that it matters... Lots of people know more about 1 make or model.... Later !!
  18. #58
    powder springs, GA
    i was talking about ignition timing
  19. #59
    Acworth
    i dont feel like getting adobe or i'd go look
  20. #60
    Acworth
    so am i...
  21. #61
    Dahlonega, Ga
    I got my ASE Master at the end of last year, and ive been toyota expert certified for around a year now.
  22. #62
    everyone check out video clip .. not the best but just look and tell .. and i dont have nething done to the motor nada.. and that loud ass shitt is my stock air intake.. everything is stock as can be i SWEAR..
  23. #63
    Quote Originally Posted by lsxtreme
  24. #64
    Acworth
    cool, i want to get my master certs but its gonna end up taking alot of time, i can only get 4 certs at NMTC, 5 at Chatahoochee tech, and i dont know where else to go. not sure if they're the same certs +1 at chat, or whats the case. i dont know where to get the other 3 certs around here
  25. #65
    Acworth
    ls, where you live?
  26. #66
    kennesaw
  27. #67
    Acworth
    lemme come see it, give me a call. 404-324-2390 i live right close to there
  28. #68
    Dahlonega, Ga
    ASE certifications have nothing to do with certs at schools, you must take ASE written tests at their test centers. there are 8 tests to become a master. in addition to passing all 8 to become a master, youve gotta have 2 years or more service experience which tech school does count toward.
  29. #69
    powder springs, GA
    his timing should be 16 degrees btdc. if i remember it is the leftmost white mark on the pulley if you have an light without a dial.
  30. #70
    Douglasville
    Sounds like a Diesel.... Did you put that shit in your Tank.... :boobies: ...Later !!
  31. #71
    powder springs, GA
    will the car rev higher in neutral?
  32. #72
    yeah it would but when it gets to it's bitchslapping mark i .. stop ..
  33. #73
    Jul 2003
    Atlanta Centennial Park
    car sounds like it has no power which can be:
    Clutch
    Timing is WAY OFF
    since you say the timing is dead on, or only a little off, that would lean me towards CLUTCH issue.
    But again, without SEEING the car, its going to be hard for anyone to make an accurate diagnosis.
    and Main Stream, im a moderator, i can seee your DELETED message
    -www.usedbarcode.net
  34. #74
    Douglasville
    Quote Originally Posted by Mr. KiDD
    Clutch
    Timing is WAY OFF
    Mike I'm sorry man But I never seen a Clutch do that, If you look at the Video He has it floored but the Tach nor the Speedo is moving... ... Later !!
  35. #75
    powder springs, GA
    if it were the clutch the revs would go up at wot in the video. yeah what he said
  36. #76
    Douglasville
    Its almost like the motor has bad gas, Wrong gas, Or just Cam Timing is off... :boobies: ... Later !!
  37. #77
    Jul 2003
    the video is too choppy for me to see the rpms or the tach. it just sounds like it has ZERO power or an incredibly long geared transmission.
    I have seen a clutch so far gone that it just wont grab an the speedo nor the tach showed any signs of anything being wrong or climbing.
    My CRX when i slammed 3rd gear, the tires would not spin, but the tach an speedo jumped. i smelled clutch and i replaced it. the disk was fried.
    i dont know what to make of it, i would need to see the car an drive it myself.
    the only "X" factor is the loud noise he keeps sayins he is hearing.
    and MASTER TECH doesnt mean anything if you own your own business. its great to have at a dealership , but we dont operate on dealership rules
  38. #78
    powder springs, GA
    [QUOTE=Mr. KiDD]i gave up cause i dont feel like arguing with idiots.
    google my name, check my credentials.
    Vteckidd
    Mike Corvey
    Mr. Kidd
    Mr. 2jzkidd
    190whp OEM GSR 5 years ago
    237whp NA LSVTEC 2 years ago
    705whp 2JZ 240sx this year
    285whp Stock SR Silvia this year
    i kinda dabble in everything, but what do i know
    later
    so youve had other people build engines and put them in your cars for you. Nice credentials
  39. #79
    Jul 2003
    if he has adjustable cam gears and they slipped, def a possiblilty i had that happen to with some old AEM gears.
    if its stock cam gears, i dont see it happening because the car just wouldnt run or barely idle if it was off a tooth or more to make it have such a loss in power.
  40. #80
    powder springs, GA
    I thought we established that this could not happed?
