Results 1 to 29 of 29
Thread: Civic caliper mounting bracket question!!
    Fayetteville/PTC/Carrollton
    Default Civic caliper mounting bracket question!!
    I got new wheels today and the offset is crazy (11) but i love the way they look so I wanna keep them (i already rolled the fenders) but the mounting bracket of the brake calipers grind the wheels really bad and I was wondering what I should do about it. Should i just take a dremel and start grinding down the caliper mounting brackets?
    is better than you..
    Somewhere you're not
    what ever tickles your pickle...
    JJSPEC Racing
    if its not much of a clearance issue i dont see a problem with that
    -2001 Lexus IS300
    no its pretty bad, the caliper bracket is making a really nasty metal/metal noise and needs more clearance.
    JJSPEC Racing
    thats what im saying, if you dont have to grind half the caliper down to make it fit i dont see where it would be a problem, shaving it a little for clearance shouldnt be a problem....
    what about spacers?
    -2001 Lexus IS300
    what about spacers?
    i might have to grind quite a bit for clearance, just wondering if it would negatively affect anything on my calipers if i ground down the caliper brackets
    JJSPEC Racing
    im sure it would weaken them....the extra metal isnt there for the hell of it, like i said have you looked into the possibility of spacers?
    -2001 Lexus IS300
    no i havent...here's a pic of it i dont think i can space it anymore lol the offset is crazy.
    http://smg.photobucket.com/albums/v7...=newwheels.jpg
    Yeah man. Fr33way's Avatar
    North OTP
    You want to take as little off as possible or as mentioned use spacers. Even under daily driving those brackets see immense heat and will warp if too much material is removed.
    North OTP
    How much do you need? A 3-5mm spacer may do the trick.
    Quote Originally Posted by Fr33way
    the problem is is that i already had to roll my fenders to get the wheels to fit on and i dont have any more room for spacers.
    JJSPEC Racing
    Quote Originally Posted by ryanh300
    you may want to hit up HT and see if theres anything you can do swap wise for a smaller caliper setup, im no so sure, havent modded a honda in a good while
    -2001 Lexus IS300
    JJSPEC Racing
    what he says, spacers can sometimes do the trick, would be more practical than going to the brackets w/ a grinder....
    -2001 Lexus IS300
    North OTP
    3-5mm really is a tiny amount but it just may work.
    Is this on one area of the bracket or across the face of it? Pics?
    i dont have pics of it on my car but i colored this pic in to show you where it is approximately:
    Attached Thumbnails Attached Thumbnails -caliper-jpg
    The white is where the bracket is rubbing the inside of the wheel, i tried to file it down but just couldnt take too much off and got tired.
    AWD OH MY KPowerEP3's Avatar
    Ellenwood
    whats the width on your new wheel? Because, if they're 8" (width, of course) wheels, you may just be able to grind that caliper bracket without any problem, because it would only be ~1-2mm difference
    North OTP
    I would say spacers. Not being able to clear those small brakes is just the wheel not fitting. I would really evaluate before going forward with this while you can still sell them before you start making changes for them to fit. Even without spacers the front track is going to be a good bit wider than the rear. I know you are probably excited about the wheels but if they don't fit, they don't fit.
    The 5mm spacer is about the size of three CDs on top of one another. You need to be able to tell how much room you need. If you have to go bigger than that, you have to start considering longer studs, and wheel bearing wear. Check with other Honda guys (that know what they are talking about) but I would think about 7mm is probably the most you would want to put on the stock studs.
    Ellenwood
    x2, however how would the front TW be wider than the rear? the offsets are the same on the wheels (I'd assume) as are the TW's. Besides, he's already gone through the motions of destroying the inside of his fenders for these wheels, he may as well use what he wants.
    Quote Originally Posted by KPowerEP3
    Yeah, i'm still debating on what to do with these wheels. I might just take a little off the calipers and take a little off the inside of the wheels. I dont know how wide they are i just know the offset is 11.
    Acworth
    Im sorry to say, but none of these options sound like a good idea. I love the wheels, but i just don't know if the wheels will work
    North OTP
    The front track is usually wider for stability in FWD cars.
    mr2 problem twincannon26's Avatar
    douglasville
    They're 7in. wide, +11 offset.
    Mad Scientist xb1's Avatar
    Athens, Ga
    Go to Honda-Tech and PM this guy: Brake_Expert
    He's local and has personally done just about every insane brake swap out there: How to put X brakes on your 96-00 EK Civic (revised) Upgrade Chart - UPDATED
    Tell hin Todd from Athens referred you.
    Someone say brakes on a Honda?
    The issue is an 11mm offset wheel. If you want to run it then you're going to need longer studs and spacers: ARP studs & H&R or comparable spacers will do the trick -- simply use washers on the studs before putting on the wheel to judge how much spacing you'll need...BUT along with that you'll need an ultra stiff suspension setup to prevent the tire from hitting the fender. Plus you'll want to replace the bearing when the hub is pulled apart.
    It's a never ending story if you're not careful with your wheel, brake, and suspension selection. Click the 2001 Integra link in my sig for more info on my Porsche brake setup...
    well i got the issue resolved today, had to do a little bit of dremeling/more rolling of my fenders but finally got them to fit, now i just gotta fix my back passengers side cause something in the fender is cutting up the tire! but all is well and it drives fine, maybe just a little shakey at about 60mph
    err yeah, that's not good...I don't like shakey in a car even at 140mph. How did you space the wheels or did you grind it all down?
    I ground the caliper brackets just enough for clearance. I can stop the "shakey" with hubcentric rings.
    North OTP
    Make sure you have enough room to account for the flex and swell when the components are at operating temperature.
    How much do you think you took off?
    BTW, 7 inches wide is probaly not worth (even though it's done) the work. Fit some 225's or 235's on 8 inch wide wheels with all that room you have now. I suppose that is a moot point now though.
