ok do a fuel preasure check, then see what color spark you get should be strong blue, then do a compression check, could be burnt valves or is your cat on? might be stopped up if it is on take your o2 sensor out an see if it cranks if it does your cat is bad, one of these 4 things should help you diagnosis !! just my .02 cents
