Thread: CHANGING TRANS FLUID IN B18 TRANS??
    southside
    Default CHANGING TRANS FLUID IN B18 TRANS??
    I DONT KNO HOW TO CHANGE THE FLUID OR HOW TO CHECK TO SEE IF I HAVE FLUID IN THERE I WAS TOLD THE ONLY WAY TO FIND OUT IS TO DRAIN THE FLUID FROM A PLUG OR SOMETHING LIKE THAT COULD SOMEONE HELP ME ASAP
    Manual trans, There is a fill, and a drain plug on the right hand side (passenger side) by where the axel splines go into the tranny. The drain plug is round with a square hole ( 3/8th's drive ratchet works great). The fill plug is up and toward the firewall it is a 17mm bolt, take it out. A good way to check is to stick your pinky in there and feel if the fluid is at the level.
    If thats too much trouble Drain it all, and add about 2qt's .
    Some good damn explanation.
    SHOW and GO! Greddypacked's Avatar
    In the castle on the HILL. Beachfront.
    ^ That sounds about right.
    XLR8SHEN FOE LizzziFeE iNsTuN nOoDoH's Avatar
    Cambodia
    Or you could fill it through the VSS hole...
    southside
    Quote Originally Posted by iNsTuN nOoDoH
    Is that the hole on the top i thought it was suppose to be checkable from there my brotha lude had a dipstick on the transmission mine doesnt he told me i could put fluid in threw a lil hole on top but i dont think the fluid will go in there but i was wondering has anyone tried lucas transmission stuff in there car
    if you fall get back on 95droppedhatch's Avatar
    in a paint booth
    you can take the speed sensor out and fill it from there and manuals dont have dipsticks normally but automatics will
