Thread: rotary and heat?
    WhatWouldJesusDrive?
    Snellville
    ok i will check my compression again an look at a new radiator cus the car is 21 years old hell i just changed out the OEM spark plug wires friday
    Snellville
    ok heres an up date on what i did i pulled the radiator and flushed the shit out of it but it was not clogged at all i mean it was very free flowing so i put it back and then checked the hoses and compression an both where good then i went to the heart of the problem the thermostat i had got a new one but when the guy at the parts place asked me what temp i want i saw a chance to make this into a fun little project ok my options at the store where 160,170,180,190 degrees so i went with the 170 while in the back of my mind knowing i was going to take it back i went home wit it and put it in and filled her up wit fresh coolant and drove it to see how it would do an as it began to warm up the temp only moved 1/4 an stayed their after i pulled over and check the coolant level and hose firmness i really got in to it and it pulls more form 3 grand to redline even in fourth gear an when i would redline it it only rises the temp to half way so i go bakc home and do some homework on this and discover that the FC3S has coolant line that run thru the intake and a popular mod it to tap off these lines to lower intake charge so i think that is why i gained a little power but the down side as with blocking off the coolant lines is that between 1 grand and 2 grand you loose power form the heated intake charge. so i guess it is true you learn some thing new every day tahnks for you help guys
