Thread: help changing MTF on 92 prelude!!
    92_screwed_lude
    Default help changing MTF on 92 prelude!!
    hey guys, just bought a 92 lude and im wanting to change the MTF. only problem is i cant find the filler bolt. i think i see the drain(its got a 3/8 square hole on it for ratchet) but where do i fill it at? someone said a 17mm bolt covers the hole but i cant fine it. any help out there!??!!??! if any one knows where to find it i would appreciate it. thanx
    JJSPEC Racing
    iirc the drain hole is the fill hole, you fill it until it starts to pour out of the hole, dont hold me to that though, google is your friend
    -2001 Lexus IS300
    BOOB koukis14's Avatar
    Pennsyltucky
    Quote Originally Posted by MJ_lude
    Don't quote me I think the filler should look the same as the drain. Or you just fill it up in the dipstick tube.....if it has one. If it does have a filler plug(it should) it is going to be towards the top of the trans. I don't work on a lot of Hondas so buy a repair manual, they are your friend. Good Luck
    Senior Member SLow_POke's Avatar
    WEST_SIDE
    Lik eMr org said .. you drain plug is the same as your filler plug .
