Results 1 to 14 of 14
Thread: rear tow hook install.. super easy...
    about this far.
    Default rear tow hook install.. super easy...
    rear tow hook install:
    cars: civic and tegs from 92 to 2012.
    skill level.. 1 out of 10 ( stupid easy )
    before install:
    tools needed:
    -18mm box wrench
    -18mm socket wrench
    -1/2 torque wrench ( you really dont need one i just like to use them, better safe them sorry )
    - lock tight.
    with my kit it came with:
    -1 rear tow hook
    -1 clamp
    -1 set of bolts with 4 washers
    step1:
    take you tow hook and clamp and bolt with washers that comes with kit.
    step2:
    put one bolt into the center of the stock tow hook and screw one hand tight and do the same thing for the front hole just on the outside of the oem tow hook.
    picture:
    step3:
    once both bolts are tight enough take you 18mm box wrench and your 18mm socket wrench and tighten both bolts. i used lock tight during this step, i like to be better safe then sorry.
    step4:
    check over all your work, and if you like torque down the bolts to about 40 lbs.. i did this just because, you can do it if you like.
    after tow hook install:
    Imy ruckus
    ~Lagg Squad~
    <turbo negros>
    I put the sexy in dyslexia.
    R.I.P steven bond....
    Aug 2009
    I like how you make it easier for people to steal your car.
    Atlanta... everywhere on i85
    I feel like tow hooks among other things is the new rice.....
    Aug 2009
    Quote Originally Posted by georgieboi View Post
    I concur!
    statesboro
    They are
    I cant believe there is a diy for this. If you cant figure this out you dont need to be modifying a car what so ever.
    Acworth
    But I already have tow hooks. Seems similar to taking the autozone lights and mounting them on your headlights.
    Quote Originally Posted by thepolecat View Post
    Lol what?
    Acworth
    Cars come with tow hooks factory.
    Mounting a tow hook to a tow hook is like mounting aftermarket headlights on top of factory headlights.
    Now I get what you was saying
    SOUTHSIDE
    Step one... dont buy a tow hook
    pointless
    Acworth
    Quote Originally Posted by Tree View Post
    Looks kinda like your car is getting fooked up the rear. lol jk Im busting your balls.
    LOL but its shiny!!!!!!
    Jan 2010
    What about the front tow hook?
    nice job man thankx
