Results 1 to 17 of 17
Thread: Custom Armrest Upholstery
    It's all about JDM.
    CA to GA
    Default Custom Armrest Upholstery
    Hey guys, just wanted to share a quick tutorial of how to re upholster your armrest. I know on most older cars the fabric tends to wear out and fall apart, but with little work and money you can get it back to stock or custom. Its a quick and easy diy project that requires little work, time, and money on material. First off, you need your supplies and the cover of your armrest.
    Tools and Supplies:
    -Headliner adhesive spray can (about $10.99)
    -Fabric Scissors (any will do, as long as it can cut fabric, got mine for $3.99 at JoAnn)
    -Phillips Screwdriver
    -Razor blade
    -1 yard or less of Fabric (Choice of material, go to HobbyLobby, JoAnn, Michaels; Prices range)
    -Iron and Iron board (If fabric is wrinkled, it comes in handy)
    Instructions:
    Gather you tools and supplies.
    So go to your car and unscrew the 3 or 4 screws where the hinge is holding your armrest cover. you endup getting this:
    If you can see, some of my fabric is already peeling off, no worries. By simply reupholstering it, the armrest will look new again.
    Next begin, locating all the screws underneath the armrest cover and carefully unscrew them. Keep track of all the screws and where they go. Mine had a latch so, you need to take that off also.
    Pry off the plastic part underneath the armrest cover. This will allow you to peel off the old fabric off. Proceed to slowly peel off the fabric, trying not to peel the cushion.
    Grab your new fabric (I chose a black cloth fabric, feels like oem cloth material. I paid $8.9/yrd), and your scissors. Lay the old armrest cover fabric over the new fabric material and cut out a rough shape.
    Grab your iron and iron board. Iron with steam it if you have to, to get rid of the wrinkles. Be cautious not to destroy your new fabric:
    Then once you are done ironing, lay out the fabric on top of the ground or safe area, and lightly coat it with some adhesive (MAKE sure you are coating the correct side of the fabric, because there is a backside and front side). At the same time, coat a generous amount of adhesive to the top/sides/undersides of the bar armrest cover. Allow a 2-5 minute flash/dry time for the adhesive before you actually join the two together. Here is how it should look.
    Then carefully and stretch the new fabric and wrap the armrest; the adhesive is really sticky and will not dry out. Get all the wrinkles out by gently pulling off and stretching it over again to wrap the the armrest cover. Get all the contour shape of the cover, be patient and wise about it, theres no need to rush. Work your way around.
    Once you have gotten most of the fabric straightened out, begin trimming some of the excess material off underneath (you'll know what i mean when you get to this part). When you finished, put the underneath cover back on with the screws and you are good to go. Go to your car and screw it back on to the rest of the armrest.
    ATL, GA
    good job, I plan on doing my headrest, center console armrest, and door panel inserts in black alcantara suede soon
    rep for the tutorial and the I heart boobies bracelet lol.
    It's all about JDM.
    CA to GA
    Quote Originally Posted by CautionMeDC2 View Post
    Thanks for rep.
    It's all about JDM.
    CA to GA
    Quote Originally Posted by RL... View Post
    Sounds good man, hope it turns out great. Cant wait to see finished results if you don't mind.
    It's going to be awesome! Can't wait to see it done Rick
    Great write up gsrteg!
    GD Lee Pitts!!!! 97ITR86's Avatar
    looks good bro. I just did my door panels this weekend. It gives your interior a fresh look.
    It's all about JDM.
    CA to GA
    Quote Originally Posted by 97ITR86 View Post
    thanks. I plan on doing my door panels pretty soon too, i'll post up a diy on it also (when the weather gets better)
    Not trying to thread jack. hahaha
    It's all about JDM.
    CA to GA
    Looks good man. Did you end up taking the whole door panel off or just reupholstered the panel on the door? I'm trying to figure this out before i actually do attempt. If i dont need to take off the panel, it will save me time and chances of breaking any clips/tabs. Let me know
    Take the door panel off. It is worth it to make everything fit correctly. What kind of car do you have?
    ATL, GA
    I just did my center console, door panel inserts are next on my list. This armrest was a little complicated and I had to get my friend to sow 2 pieces together to make it look oem-ish.
    before: you can see a tear from being used/old
    after:
    ATL, GA
    I just wrapped my door panel inserts in suede as well!
    The Fuck allmotor-teg's Avatar
    Dec 2010
    down in georgia
    very good guide, should be doing it myself!!!
    ​Hold On Not Done Accelerating
    It's all about JDM.
    CA to GA
    after:
    Nice job man. Glad to see the finish product.
    It's all about JDM.
    CA to GA
    Quote Originally Posted by allmotor-teg View Post
    yea, you should. its a quick weekend car project.
    Dec 2010
    down in georgia
    Quote Originally Posted by gsrteg View Post
    ^ ill even try and do the interior, roof all that stuff.
