I've found this engine "B20TC"
It gives 250hp stock
I never seen this before, anyone?
				x2 and damnOriginally Posted by fininfarina
BTW do u kno wat car its out of?
				looks like a b20 with a vtec head to me. raised speculation.
engine is on this EG2
compare with B16 vtec
B20TC KONPURITOENJIN (250 PS version)
Polishing port
FEEL'S ECU Sports
Injector process
FEEL'S EKIMANI (INTE R)
HITOINSHURETA
Throttle body
IN manifold (INTE R)
FEEL'S lightweight flywheel
Metal clutch set FEEL'S
FEEL'S metal catalysts (INTE R)
Barnacle sport muffler
Air cleared for K & N NSX
Create EAKURIDAKUTO
Trust iridium plug
Hot Wire Technologies
FEEL'S ASHINGUSHISUTEMU
Infinite set of engine mounts
FEEL'S processed oil pan baffle
ACG A / C P / S belt
Indoctrination TAIMINGUGERUTO
INTE R for use INMANI throttle body parts
Seal oil and nuts
Infinite FURUBUSSHU
(Tentative attached) R genuine damper INTE
Brake master
FEEL'S brake hoses
FEEL'S front SURITTOROTA
FEEL'S rear rotor
FEEL'S sports front pad
FEEL'S rear pad Street
Flat screw
BP BUREKIFURUDO
New exchange-cloth
Master clutch
KURATCHIMASUTASHIRU
Clutch slave
FEEL'S clutch hoses
KURATCHIFURUDO (BP)
Defi sound meter hydraulic oil temperature gauge
‡U control unit
FEEL'S oil block
Temperature Sensor Adapters
translated from google
I hope your not taking this guy seriously!
cant be a f seriesOriginally Posted by PBS
the valve cover is like a b series all f series look like h series with the dohc vtec on the bottom
AKA HIZDAWAY
reps because you read my mindOriginally Posted by ACCORDPRIDE
Interresting!
"Damn, Its Tyler"RaceReadyDevelopments
I'm not playing with youOriginally Posted by Truegiant
I found this in forum in Japan
That was why asking you guys
you![]()
that and the block looks way differentOriginally Posted by ACCORDPRIDE
Yeah, looks like a FWD F20B to me.
FEEL'S in Japan makes and sells that motor
^^ +1 for droppin the true knowlege.....
Da Nastyist Whipz Member #9
there are many small shops in japan that make crate motors for honda
Wow.. I meant the translation.. looks like something you would get off an ad on craigslist. Half translated half not. I am screwy huh..![]()
correct! it's a feel's crate motor.Originally Posted by NAIZBST
you can find them in the old jdm mags - they have ads in the back with this motor.
Originally Posted by Tasuki_Civic
