Page 1 of 3 123 LastLast
Results 1 to 40 of 108
Thread: my build!
    Default my build!
    some more pics
    when i took out the engine...
    engine sitting on a little trolley
    pulled off the intake/exhaust mani's
    The bare block turned around...im building this on the floor..no engine stand :wgaf:...2 of my friends offered for me to borrow theirs but idk never got around to it...
    another shot of the bare block
    The table of the entire bottom end waiting to be put in after my ACL bearings get here...
    My room with the entire top half of the engine...yes this is where i sleep.
    A drawer full of ziplock baggies labeled with parts to exactly where the go on the engine. over 40 bags.
    my dresser with parts from the engine bay (intercooler piping, strut bar , heater hoses and alternator/starter)
    the upper oil pan...cleaned the outside with Engine Brite degreaser and the inside with gasoline...did the same with the lower oil pan also..gas..(this is below the table with the bottom end parts, radiator,driveshaft and shroud are sitting around here too)
    Attached Thumbnails Attached Thumbnails -100_8771-jpg
    if anyone is wondering why im building its because i spun a rod bearing in cylinder 3 coming home from last varsity.
    ..hopefully it should be done before the next one..
    ordered ACL bearings...should have been here already but stupid memorial day
    ordered headgasket. should be here tomorrow
    bought a new crank because mines was fubar.
    bought new rods and pistons because my cylinder 3 rod was bent.
    Earth
    My wife would kill me if I had parts all over the house like that..lol Good luck with the build!
    lol just a corner of the garage and my room...
    SHOW and GO! Greddypacked's Avatar
    In the castle on the HILL. Beachfront.
    at least your not worried about any parts missing or stolen.
    ^^ made no sense...
    organization is key...it is a bit overkill but better safe than sorry.
    my momma's house
    good shit man... we are in the same boat. Ziplocks are my fucking best friends right now.
    Trend settin'
    hahaha ziplock's and post-it-notes...cant ever have enough of them.
    HIV+ HalfBaked's Avatar
    Yea...I pretty much just put all my bolts and parts into a box and let them mix up.
    lmao halfbaked...that would be crazy. potpourri of bolts
    Where Am I
    ^^^ LOL yea that wouldn't work for me either I had lables on everthing, when I did my swap, I used cups instead of bags, LOL.....
    swap and build wayy different...when i did my first swap i didnt label anything just went ahead and did it.
    Senior Member BlueHatch's Avatar
    Green Acres
    oooo damn if i had my top end sitting on the carpet like that i would be shot. then thrown out. my wifey gave me the garage and it is F'n chaos in there. bump for your organization. i envy you my friend. think you could sell me some of your ocd?
    Last edited by BlueHatch; 05-29-2007 at 08:08 PM. Reason: sounded rude...added smiley
    lmao OCD ftw...i had some tarp i was gunna throw down but im gunna overhaul my room soon anyways so carpet i dont care about but i laid down some old shirts anyways..
    is better than you..
    Somewhere you're not
    LOL your mommy didnt say anything? AHHA
    did your mommy say anything when i took a dump on your carpet?
    stupid retard sent me a FWD headgasket for the SR20...going to have to wait until i get a new one or if nissan has any in stock or nopi...doubt it
    Nice bro
    EX Super Mod TIGERJC's Avatar
    Fayetteville
    yo you already have the motor out, now is the perfect time to put a real motor in it (2jz or 3sgte).
    2006 Evo IX - Bolt ons
    hahaha yota lover. N4L man N4L
    (nissan 4 life)
    Fayetteville
    did u measure your crank to make sure no damage was done to it
    for doing your on work
    oh...the crank lol...i just looked at it and threw it in the trash, it looked like 40 grit sandpaper on one of the journals..
    .bought another one...still going to plastigage and everything...
    INFINITE TRDwasiq's Avatar
    Quote Originally Posted by BenefitX
    Actually i am the one who is doin the build he is just takin pics and stuff
    wish me luck
    yea its true
    DRFTR empty your PM box!
    'Round These Parts
    What caused the spinnage?
    How many miles on the motor?
    Leisa and S. 4 Life NM?
    IDK
    i think motor has around 50k
    'Round These Parts
    I'd be pissed if mine did that - i drive conservatively for the most part - but it gets kicked when it needs to be.
    yeah, the motor has around 50~60k, from what ive read and heard, SR20's have an oiling problem in cylinder 3 and are real oil hungry...turbo was eating oil, i think i had a bad front seal..alot of blow by so yeah it was deprived of oil.
    'Round These Parts
    Was the oil pan dented?
    no it was'nt
    got my bearings in today...worked for the past 4 hours putting the bottom end together...
    Installed main bearings
    Installed crankshaft
    Installed crank caps with new bearings
    installed rods and pistons with bearings
    installed rod caps
    installed bearing beam (girdle)
    installed oil pick up
    installed rear main seal
    installed oil pump
    installed water pump
    installed oil filter plate
    installed upper oil pan
    installed oil pickup
    installed baffle plates
    installed lower oil pan
    installed engine mounts
    installed flywheel
    installed clutch/pressure plate
    installed timing chain w/ guides
    installed alternator bracket
    installed alternator and belt
    installed crankshaft pulley
    uhmm thats about it until my new headgasket gets here cause some idiot sent me a fwd one...or else i would of gotten it running today
    and the piccy's after all the work was done...(i dont really take breaks for anything, only after im done,which is why there is only 2 pictures lol)
    good JOB+1 for ya
    'Round These Parts
    Good Work so far!
    thank you...damn i get too hasty , almost thought about reusing my old head gasket and just starting her up tonight...but i think im gunna wait...new one should be here by wednesday...
    how she sits at the end of the day...(just put the head on there for now, and the VC, if i was really this close i would still be working on it)
    Sweet N Low Ltdnismorace's Avatar
    North
    looks real good man, If I lived down there I would have definately helped you out
    hey ltdnismorace you decide to keep the 240?
    my momma's house
    berry nyce! +1 sammie...+1, indeed. lol.
    Trend settin'
