Results 1 to 14 of 14
Thread: How long to run a system with cap
    Exclamation How long to run a system with cap
    I was woundering how long i would be able to run my system during car shows with it off..i have 2 power akoustic 3flared caps 2 2400watt amps pushing 2 15' kicker L7s.
    Kennesaw, GA
    untill your voltage drops below 11. which, judging by all the stuff you have, will not be too long. all depends on your charging system. If your still running on a stock battery, i'll give you 10-15 minutes if that
    NIKON Squad member 01
    OF*C
    OEMFitment Crew Memeber 01
    Alpharetta
    get a new battery and a spare to change lol
    Blacc Panther member
    look to ya left
    I have some what of the same system... 2 audiobahn 2 farad caps... 2 JL 1000/1 amps.. fosgate crossover.... clarion EQ.... and a red top... need another battery badly after about 20 or so minutes it drops from 14.5 to about 12.9 then i start the car.. let it sit for awhile
    what kind of car has room for two fifteen foot speakers?
    Hiram, GA
    what does a cap have to do with how long you run your system with the car off?
    Certified Gearhead gobraves00's Avatar
    dallas, ga
    a cap is there to help with deep surges the amp puts on the battery. a cap is not a battery source. if you have a batcap then you could use that way, but it doesnt have a way of recharging itself. if anything just hook up a voltage meter to your battery and keep an eye on it.when it gets around 11 start up the car with stereo up and recharge battery, but it not good to keep running it down and back up to many times.
    jimmy..doing any shows anytime soon?sorry for the highjack
    Kennesaw, GA
    Jimmy, do you have AOL?
    OF*C
    look to ya left
    digi caps show the voltage of the BAT .. thats why i say keep and eye on IT
    Cumming, GA
    With the engine off, your system runs off the battery, and the battery alone. If you want to be able to play your system for a long time with the engine off, you only hope is to add more batteries or get a power supply, and plug it into the a wall outlet. Wall outlets are not always around when you want to "hang out" though....
    Now, if you add 3-4 batteries, you still have to (highly suggested) seperate them from your main car battery. This way, if you drain the 3-4 stereo batteries, you can still start the car to go home because you have (seperated) isolated then from the car battery. Also, you will now be asking your alternator to charge 1 fresh batery, and 3-4 dead batteries. This will create a strain on the alternator, so be careful there too. You also might want to look into upgrading the alternator at some point.
    [QUOTE=redgst97]plug it into the a wall outlet. Wall outlets are not always around when you want to "hang out" though....
    QUOTE]
    what do you need to do this???...i know its some kind of converter but not sure what kind or brand to go with
    Hiram, GA
    lots of electrical upgrades should be done with multi battery set-ups.
    no shows anytime in the near future, but you never know.
    Cumming, GA
    I have one from Cascade for my Eclipse, and one from Stinger for another car.
    The Cascade was custom built for me, and was around $700. The Stinger is a little more "main stream", and will se you back about $350 or so.
    Depending on what part of town you live, I might suggest some of the stereo shops. Most all of them can order it for you. I know Area41 (IA Sponsor) or Traffic Jams can bothe get one for you.
    i dont noe
