Results 1 to 16 of 16
Thread: Engine degreaser....engine bay clean up...
    Default Engine degreaser....engine bay clean up...
    What's some good engine cleaners? I've had an oil leak for the longest and my bay is really nasty (oil everywhere). This is why I never pop my hood at meets. Well I want to clean it all up so I can see if I can find the source of the leak. And to possibly show it a little more.
    Also, how best to clean the engine bay?
    Thanks to all. Later, QD.
    Scottish Scotsman's Avatar
    on the road to recovery
    purple power , mild pressure wash , cover as much electrical as you can
    Projects
    Quote Originally Posted by Scotsman View Post
    x2 Its awesome now idk if the kind sold in stores is different but i had a jug from a CAT tractor repair for cleaning. It did great the first wash barely had to do any scrubbing...
    2SL0W4U AZN_Pride's Avatar
    Dothan, AL
    I used the Engine Degreaser Gel from Autozone and it seemed to have worked rather well. Purple power is great too.
    I hope there are pics once you are are done cleaning!
    Certified Gearhead dc2gs's Avatar
    Oct 2011
    cartersville
    I use simple green usually and sometimes purple power. (Simple green has worked better IMO) cover up your air filter, dizzy, alternator, and starter with some plastic bags. Then wet the bay with medium water pressure. Spray the degreaser or soap of your choice and cover the whole bay. Let it sit for a few minutes and then go ahead and start scrubbing both fender sides and firewall with a soft brush, you can also try brushing the motor and any other parts you want cleaned. (Just be careful not to wet anything that shouldn't get wet) you can rinse and spray more degreaser if needed to any spots you missed. finally rinse off the bay and dry as much as you can. Start up the car and let it run for a few minutes, this should help dry the motor and any electrical cables that got wet. I managed a detail/ carwash and this is the way we did it. Good luck man, hope this helps.
    I also use a jug. I fill a bucket with it and clean suspension parts, brackets, etc. Just let it soak, scrub a bit, rinse and you're done.
    McDonough
    Purple Power, Spray 9, or any other industrial cleaner.
    Bitches love bacon.
    forget all of them awesome from the dollar store does wonders
    ATL DA SQUAD MEMBER #1
    HONDA_PARTS_CLEANUP_CLICK_ME
    what he said...spray it let it sit for like a min rinse end dirt/
    Quote Originally Posted by jadakid88 View Post
    FREE BUJU StarBwoy's Avatar
    IDK
    true story ish works
    DA SQUAD MEMBER #90
    AWOAH
    [SIGPIC][/SIGPIC]
    i've always used full strength purple power, rinsed off my fenders so any purple power overspray wont eat up the paint, spray the entire bay (not covering anything) with purple power, start the vehicle up and clolse the hood let teh car heat up for about 5-10 minutes and spray the fenders again while waiting to spray off any degreaser overspray, pop the hood and let the garden hose at it. only time i had a proble was when my distributor cap had a hairline crack in it and it had a skip..replaced it, car was fine. no need to cover the alternator and all that jazz
    McDonough
    Quote Originally Posted by Sammich View Post
    .....no need to cover the alternator and all that jazz
    I was thinking the same thing as well. It gets wet normally anyways.
    Bitches love bacon.
    Sep 2003
    Typically I drive to the car wash, pop the hood and spray this all over the engine bay
    then pressure wash the bay down. Drive home and spray this on everything I want shiny
    wait 15 minutes then use a paper towel or micro fiber to soak up the excess...done!
    Nov 2009
    canton GA
    I just cover the air filter so it doesn't get wet and attract dirt. I actually wash it with the motor running. have to agree the orange cleaner from the dollar store works great. I have a slight upper oil pan leak that gets my bay messed up too.
    Best G20 SR2009 convention
    top 20 hotlanta autofest 09
    i dont cover the air filter, even when i had a aftermarket intake, but yea i do rinse it off w/ the motor running...generally i do mine while i wash the car, keeps it simple, by the time you finish drying the car off a majority of the car will be dry you can take it for a spin and get the rest of the resting water off the engine
    cravin a s2k
    Cookeville, Tennessee, United States
    i always cover the distributor or dont spray around it. but thats the only thing i every cover up. for heavy build up i always pressure wash the excess off first. then use brake parts cleaner on the block and use a scraper and brush to get off anything thats caked on. after ive done that then its just purple power and pressure wash.
