Results 1 to 7 of 7
Thread: 97 B18c1 spun rod bearing need help?
    Jun 2009
    Default 97 B18c1 spun rod bearing need help?
    spun a rod bearing ..im limited on oney i have 600$ what should i do?
    machine shop is charging me 1000$ to fix..anybody know some where thats cheap and good? i live in gwinnett
    anybody got an extra gsr block? ANY SUGGESTIONS....
    Buy a ls short block, and ls vtec kit.
    Newbie Photodude RBS's Avatar
    All Over U S A
    buy a gsr shortblock
    buy a crank and 1 rod. Simple as that. Most cranks go for about $100 and a rod is about $20 used so just do that and rebuild. or buy a short block, they are only a few hundred bucks.
    My line of work
    www.internationaljets.com
    IA Member donek9's Avatar
    cochran, GA
    when i spun a bearing in my old b16 i pulled the motor and disassembled it myself, and took my crank and rods to the machine shop. they turned my crank and resized all 4 rods for $130, got acl rod, main, and thrust bearings for $75, rings were around $75, and oil pan gasket and new front and rear main seals were less than $50. all thats left is to hone your cylinders and put everything back together. i did this over 2 years ago and although i recently sold this motor its still running just fine.
    SOUTHSIDE
    x2
    eazyist fix right here....
    Quote Originally Posted by RBS View Post
    __DailyGrind
    i got a gsr longblock 600 come get it
    you can sell the head.
