Thread: Boost: JDM B18B or B20B
    South Side Georgia
    Default Boost: JDM B18B or B20B
    So I just found out my block are done. Now I on the market for a JDM LS or B20 to boost. I'm looking to only boost on the wastegate which is only 6.5 pounds (TiAL 38mm) but not sure which I should buy.
    S2 70mm Throttle Body/ S2 intake manifold
    780cc injector/ resistor box
    Peakboost Turbo Kit w/ 60-1 turbo
    Transmission will be a JDM GS-R w/ LSD
    I heard B20B are really good on boost but I found both at the same price.
    resize pic
    Stang Mod slostang's Avatar
    Southside
    go with the b18b
    the b20's sleeves dont like boost AT ALL.
    Where Am I
    go with the b18b
    ^X2... Not trying to be mean but this has been covered like 1355929384393 times
    South Side Georgia
    Maybe it have but I honestly never thought I would own a LS motor. This is only as a big-up plan.
    resize pic
    E46 M3 Z0_o6's Avatar
    Suffolk, VA
    Does it absolutely HAVE to be a JDM engine? What difference does it make?
    Go with the LS, they generally hold up better.
    Who knows?
    known as Charles
    Are you planning to run stock internals? Unless you plan on sleeving then I would go with the B18 like everyone said. The B20 sleeves are thinner.
    Main Stream Performance
    www.mainstreamperformance.com
    MSSracing.com
    South Side Georgia
    JDM B18b and USDM compression are different. Yes I plan to run stock internal on only 6.5 pound of boost.
    resize pic
    just go b20, resleeve it and the boost away. 84mm is pretty fun to boost with.
    turbos
    compression differnce is minimal unless u r talking b20z compression
    that will requre a skilled tuner or it will break
    just find an ls and be done with it (decent power for a decent price)
    TOO BIG
