Results 1 to 18 of 18
Thread: A/C compatible manifold
    Jun 2009
    Phenix City, Alabama
    Default A/C compatible manifold
    ok well im putting together a turbo kit and i would like to keep A/C. so my question is what turbo manifold would i need to get ?
    IA MEMBER turbob20's Avatar
    LaFayette Ga.
    i ran ac with my cast rev hard manifold and inline pro.as long as the exhaust down pipe is on the pass side usually ac will work with a cast one.fabbing will rout any way you want.
    Jun 2009
    Quote Originally Posted by turbob20 View Post
    are the cast iron manifolds A/C compatible ? is that what the rev hard manifold is ?
    Aug 2009
    there is a full race ram horn in the parts section with a/c which motor
    Jun 2009
    Quote Originally Posted by getherdone View Post
    i dont need a race one. im gonna run 10 pounds on a d16z6. im gonna put a slim fan on also.
    Jun 2009
    can i run A/C with this manifold and a slim fan ?
    roflcopter V-Spec II
    Norcross
    Quote Originally Posted by ej1boy95 View Post
    Full Race is a company, if that's what he meant. They make some BEAUTIFUL manifolds, and they know their shit. I don't know what kind of budget you're working with but you could call them up and for the right price they could fab you a manifold that would clear a flux cap if that's what you needed.
    Jun 2009
    Quote Originally Posted by MongolPup View Post
    thanks but im on a really tight budget. lol
    known as Charles
    Full Race doesn't make a A/C comp for the dseries just the bseries and even then you still have to move some stuff around (have one here now). The cast one you have picked will work but will be a little tight on the condensor and rad because of how far away from the head the turbo mounts. Also, the wastegate dump tube will be a little difficult. Your best bet would be a log style cast manifold.
    Main Stream Performance
    www.mainstreamperformance.com
    MSSracing.com
    Jun 2009
    thanks for your help. do yall know any cheap top mount monifolds for the d series ?
    ACC CHAMPS bigdare23's Avatar
    ECEFC.com
    Why do you need a top mount? Is you motor fully build (sleeved?)?
    Since you're in Alabama why not talk to Greg at go-autoworks since they are local to you. Plus, he specialize in d-series
    Jun 2009
    Quote Originally Posted by bigdare23 View Post
    i just figured top mounts would leave plenty room for the A/C. but where is go-autoworks ?
    Senior Member cm7k24's Avatar
    kennesaw
    umm idk about that.
    i was in the same situation and the top kpfab top mount manifold was far from fitting in my coupe. Greddy log mani fits fine.
    Certified Gearhead jojeezek's Avatar
    Jul 2009
    Just take the A/C out. It robs power anyway. Your turbo build will be easier and cheaper that way too.....The Slim fan will help. Just make sure its mounted right because the slim fans barely have a shroud.
    D16 + Turbo = The Replacement for Displacemnt
    Jun 2009
    Quote Originally Posted by cm7k24 View Post
    umm idk about that.
    thanks
    Certified Gearhead wwli's Avatar
    Top mount like this?
    Found it here
    EK needs a new tune? baby needs more boost so a good tuner is needed....anyone?
    Put a used greddy kit on it..... Fits like factory and perfect on a tight budget.
    ballin on a budget hondalover00's Avatar
    ga
    call greg at go-autoworks in montgomery...he is the d-series dude you would like to talk to....334-467-4171
