Results 1 to 29 of 29
Thread: stock ls engine on 50-75shot of no2
    Default stock ls engine on 50-75shot of no2
    How Much Can it Hold safely
    like say nitrous wise, can i be able to do a few runs on the tracks?
    I'm just shooting for like 50-75 shot 8D
    /Oo ___A___ oO\
    |=_/_______\_=|
    Jul 2009
    if i remember right 50 is safe with no retard....
    75 you gotta start retarding ignition
    Stang Mod slostang's Avatar
    Southside
    200 single stage dry shot. do it.
    Jul 2009
    did you know you can inhale nitrous and get high?
    fuck going fast
    i just might try the 50 shot then since no tune or retard of the dizzy is needed
    /Oo ___A___ oO\
    |=_/_______\_=|
    283.5°.516"(13.11mm) DirtyMechanic's Avatar
    Alpharetta, Ga
    Quote Originally Posted by dallasb84 View Post
    fuck going fast
    wrong kind of NO2. you would die if you did anything like that.
    The G Spot Hero
    "Nitrous is like a hot girl with STDS, you know you want to hit it but your afraid of the consequences."
    Kennesaw, GA
    Quote Originally Posted by DirtyMechanic View Post
    It is the same exact kind of gas, N20, but medical grade is mixed with oxygen before you inhale it
    NIKON Squad member 01
    OF*C
    OEMFitment Crew Memeber 01
    Jul 2009
    mmmmmmmmm ok
    LOL, my buddie ran a 300 shot, 2 single nozzle 150's, dry on his B18B. All it did was burn up the intake valves on #3. Ran a 12.8 @ 90. Most of the time if you run to much thats all it will do. Another friend thought that the number on the jets was the size of the shot...it took me rebuilding his head twice until he finally told me what was going on. He had a .075 jet in 5177 kit
    Quote Originally Posted by Jenson View Post
    so that means??
    cause i'm a newbie to teh forced inductin world
    /Oo ___A___ oO\
    |=_/_______\_=|
    Alpharetta, Ga
    Quote Originally Posted by .blank cd View Post
    the NOZ or ZEX NO2 that your bottle has. has other chemicals in it to prevent people from breathing it in. you would get sick and probably die if you tried to inhale the bottle contents in your trunk.
    The G Spot Hero
    Canton
    GO BIG OR GO HOME!
    150 Shot.
    Try not. Do or Do not.
    Kennesaw, GA
    Of course it does
    Its N2O by the way, NO2 is nitrogen dioxide. totally different
    OF*C
    Jul 2009
    it has sulfer in it......
    Alpharetta, Ga
    ha i knew it!
    The G Spot Hero
    Jul 2009
    but it can be filtered out with a organic filter that you can buy at lowes for right about 9 bucks.......
    its how all those idiots at raves sold whip hits in ballons back in the 90s and 00s
    Quote Originally Posted by VickNotic View Post
    so that means??
    Its been a while, but if I remember correctly, on a 5177 kit which is your standard EFI dry kit for a return style fuel system, a .075 jet would be a 150 shot since the powershot solenoid orifice is .065.
    In my experience, anything over a 75 dry shot on a honda intake manifold requires it to be a direct port. I was able to run a 100 shot but I had to redirect the return from the fuel pressure solenoid thing back into the intake tract but it still hit #3 really hard. It would eat a plug every 3 runs. The standard way to run it is just T'd back into the nearest vacuum port on the manifold. The stock manifold just doesnt distribute evenly enough for a single nozzle at that level.
    I easily ran a direct port dry kit @ 150 on a stock type R manifold, stock bottom end B18C1. I got the idea from said friend who had been running the same setup on his stock B18B for a while.
    Jul 2009
    50 shot fogger...... and youll be a ok for a good long time.....
    everywhere & nowhere
    Pussies run nitrous.
    Jul 2009
    gangsters run bitches
    IS300 NEMO's Avatar
    We Fuckin...
    i had my stock LS on a 55 zex wet kit hooked up wrong and it ran fine but as soon as i bumped up to a 75 it didnt last long before i melted a piston. but this was all because i had hooked it up wrong
    Senior Member EJdm's Avatar
    my buddy ran 80 shot in his b17
    Southside of The Jungle
    There is a guy on youtube that my friend knows in Florida.He has a 150 shot or 200 cant remember which.But his crx with bone stock ls runs 11.3 I think its on youtube should be all juice Tony or Toni.And he sprays from the line all the way through the quarter.
    IA Member RACEMYCOPCAR's Avatar
    Jul 2009
    West columbia, SC
    A 60 shot should be fine, youll pick up more torque than HP which hondas are short on.
    91 Supra.
    VIP IS THE NEW RICE!!!
    NO ONE cares about or is impressed by the cars you USED to own, why don't you put all the cars in your neighborhood in your sig as well, you don't own those either!
    Quote Originally Posted by RACEMYCOPCAR View Post
    well whatever I pick up it should be better then stock, and j/w why are there so many brands such as
    zex/nos/NX/jackson's/ etc it's pretty much the same thing right?
    /Oo ___A___ oO\
    |=_/_______\_=|
    It's just like anything else and really fits the person. There is no "best" system. The "best" systems are mutt systems.. for example, the old school NOS (holley) bottles have the best flow out of the bottle valve... NX has the best entry-level and mid-range solenoids (when I say best I mean reliable, not highest flowing), ZEX has the easier installations w/ "the box", etc. No flared jets are interchangeable b/c each manufacturer is aware of the flow differeneces between their bottles noids and jets. So the numbers on the jets to make the same HP will never be the same from manufacturer to manuafacturer b/c they each have different flow rates, nozzles, etc.
    A good safe kit that has shutdown if you lean out is Zex. It's commonly accepted to be the safest out of the box. On an import EFI system w/ such a small shot and as a 1st time used I'd run Zex or NX.
    +1 for Zex. It is the safest kit to use, as stated before "the box" will shut it off if you run too lean.
    Rice Rice Vtec
    SHOULD BE FINE MAN
    95 Civic EX-Traded
    93 Civic CX -Sold
    93 Nissan Altim-Sold
    95 Civic CX- RIGHT NOW!
    IA MEMBER turbob20's Avatar
    LaFayette Ga.
    75 shot is fine ran it for 3 years before going turbo with no retard and 1 step colder plug. even popped in 100 shot with bkre7s i think and 2 degrees retarted.
