Results 1 to 17 of 17
Thread: gsr turbo bad vibration?
    sleeve me please?
    monroe
    Default gsr turbo bad vibration?
    made a pass last night at commerce at 16lbs. an it backfired 3 times durring the run and i slowed down and after that whenever i get my motor at 2300,3000,3400 rpm i get a vibration i drove it home and it drove fine there is still that vibration havnt had anytime to check i think its a motor mount
    anybody ever had this happen or got any odeas
    West palm beach
    Quote Originally Posted by jap_racer1
    is it tuned ?
    Duluth, GA
    every turbo honda I see at commerce backfires at least three times...
    check plugs, cap, rotor, motor mount, axles.
    backfire makes me think ignition issue, but if you had a mount going then the motor torqued hard enough it could've busted the mount that was already bad.
    sleeve me please?
    monroe
    new plugs new rotor button and cap mounts r original so im guessinng mounts it runs fine only backfired then now it just vibrates when i get near certain rpms other than that it runs fine??
    if it vibrates at certain rpm then it's probably mount or axle related since it happens at a certain rpm.
    sleeve me please?
    monroe
    yeah the motor is sitting low on the driver side cv axle boot is like 1/2 cm. from the frame!!
    so the main question is, what did it run even backing out of it
    sleeve me please?
    monroe
    i ran 14.2 shitty run if it wasnt backfiring and i didnt let out i would have run under 13 which is still slow as hell
    well i figured out the complete problem today!!
    being lazy me i let a shop change my upper driver side mount well they only put one bolt into the side of the block and there was so much tork it rip it off the block and took a good chunk out of my block so i got screwed on that end!! so now theres only two bolts in that mount!! shitty as hell!!
    sleeve me please?
    monroe
    this is to the person trying to tell me that a wire came loose all the sudden when i figured this out like 2 months ago as that redneck guy says
    heres your sign?
    Middle, Ga
    Simple: Its falling apart! LOL j/k
    "Damn, Its Tyler"
    RaceReadyDevelopments
    sleeve me please?
    monroe
    alright i got it rideable will fix moreo tommorow!!
    02 WRX patrick4588's Avatar
    warner robins
    so only 2 bolts holding the mount onto the engine?
    GCO Member
    NRA Member
    check the the half shaft. IDK but i had a similar problem and i bought a new half and the vibration is gone. But idk im just throwing that out there maybe it could help....
    sleeve me please?
    monroe
    yes only two bolts!!
    IA MEMBER turbob20's Avatar
    LaFayette Ga.
    see if a plug wire may have popped off! that would explain the back fires and the vibration. also could be a stressed axel seperation..
    LaFayette Ga.
    well help yourself next time and dont ask for help when your too sorry to even work on your own POS! letting some other guy work on your shit is like letting some other guy screw your girl...DIY...
