Thread: I think i'm having fuel issues.
    Ohio asshole.
    Default I think i'm having fuel issues.
    As the title says. A boosted B20 no vtec
    When I'm driving, out of boost, the car runs fine. Pulls fine, does everything fine. As soon as I boost over 5psi it seems like the motor is flooding out. A good friend is burning me a chip tonight from a well running boosted B20 with a VERY similar setup. We've done some mild street tuning and it just doesnt seem to get any better. Sometimes, i can't get into boost at all.
    Could it be that my phearable basemap is flowing to much fuel? I'm running 450cc DSM's on a phearable chipped p28.
    Also, could it be my pressure regulator going or have crapped out? The first half hour to 45 minutes of the driving, after a 2-3 minute idling warm up the car runs fantastic, infact ran a 13.7 on bald street tires and low air pressure. After a while though, it just seems to run like its loaded up and cuts out, and seems like its getting way to much fuel.
    I have a 255 fuel pump, I plan on installing, but in no way should i need that at only 9-10psi
    02 WRX patrick4588's Avatar
    warner robins
    removed since double post
    GCO Member
    NRA Member
    warner robins
    i would run a 255 if you are boosting at all. and i would get a wideband to monitor things. i severly doubt you are doing any street tuning without a wideband. and if you had a wideband, you would know if you were running too rich or not.
    GCO Member
    NRA Member
    IA MEMBER turbob20's Avatar
    LaFayette Ga.
    its your map sensor going haywire. cause on my phearable chip mine would do fine till 5 psi too. i had to get scotty to tune it because phearable dont base in for the map sensor like they say they do but untill i tuned i used a missing link and it will stop till you get a real tune.and get a walbro 255 for any nos or boost. check and make sure you tune for what psi you want to run and no more than 11-12 psi on the stock map.
    Ohio asshole.
    Well, I'm on the stock map, running 10psi now and running STRONG!!! However, i pushed 70psi of oil, and forgot to put a restrictor in, and blew a seal. A rebuild kit will be shipped tomorrow morning. As well as a restrictor
    Also as it turns out, I did have an AEM wideband. It went haywire, after a simple phone call, I was re-imbursed after telling them I no longer needed it and was going N/A I was completely reimbursed minus shipping of course, and the wideband was sent back.
    Now, i'm running the NGK 91101 AFX and its working great! I can't wait to slap the slicks on it this week!!!
