Results 1 to 10 of 10
Thread: 1984 crx si
    Columbus
    Default 1984 crx si
    ok, so on sunday im picking up a 1984 crx si. the guy has dropped a d16a1 motor in it. now he said the previous owner had slung a rod but not sure, could jsut be knocking really bad and internals need to be replaced. my question is this:
    what motors can i fit into a crx without have to cut or do anything to dramatic, if that makes any sense. i know the first gen integra motors fit. also how much do they cost roughly. i don't want to put a slow motor in it but i know u cant do to much without having to cut anything, ect. im new at this so any help would be great, thanks
    i dont know if you realize it, but the d16a1 is a first generation integra motor. so if its already in the car, you could swap in a ZC. they are practically identical and make a little bit more power. i think the d16a6 will fit as well. anyone help me out here. lol
    Columbus
    ya man, the d16a1 is a 1st gen teg motor, they bolt straight in if my research is right so far. i didn't know about the zc. thats what i want to drop in, but don't know how well it fits. a6 would be good to. thanks man!
    E46 M3 Z0_o6's Avatar
    Suffolk, VA
    first off, the crx Si model didnt exist until '85. secondly is it a PGM-FI car? if it's carbeurated you may as well start shopping for a parts car to convert it to fuel injection if you want to swap it.
    Who knows?
    Don Mon SiRed94's Avatar
    Morrow 30260
    Quote Originally Posted by hondabuilder
    QFT... CRX Si models started in 85... make sure that it's atleast an 85 model and make sure that its Si.... because it could be that its a carbed model and he swapped it in thinking everything was gunna be plug and play and then realized he was in over his head and decided to sell it... unless he just went through all of the trouble of converting it....
    Morrow 30260
    and to answer your question.... the brown top DOHC ZC will bolt directly in and so will the D16a1.... if he has truly done the D16a1 swap already, you will not be able to go back to the D15a3/EW4 platform without changing the hubs....
    Morrow 30260
    if you haven't already found this site... it has every bit of info on these cars that you could think of.... www.redpepperracing.com
    if you need anymore help just pm me, I do alot of work on these... and if you for some reason decide not to pick this car up lmk....
    Columbus
    ok, i know he said its an 84 but it has a sunroof and calls it an si...y i wuz confused. he told me he swapped the d16a1 into it, fuel injected, and ran it for a while then sold it. between the drivers the motor blew, slung a rod, he dioesn't really know. i do not know exactly what makes the car an si so u could help me with that.
    Morrow 30260
    Quote Originally Posted by 95integrals
    si will have a sunroof, 145mph speedo if its an 85, and a duckbill style wing if its an 85 also 13" 4 large spoke wheels....
    Morrow 30260
    will look like this...
