Results 1 to 11 of 11
Thread: B16 head gasket
    Southside Ridin HATCH
    Default B16 head gasket
    sup guys i need to replace me head gasket on my B16a but i was just wondering if I should get a THINNER gasket or just keep stock compression????thanks ahead of time... LMK
    use a stock one.,
    thanks....
    Around metro-ATLANTA & IA!!
    yup less problems
    Senior Member 99SI's Avatar
    Jackson
    If you really want to bump compression mill the head a few thou and run the standard three layer HG, seals better and leave you with a much more reliable set up.
    Don Mon SiRed94's Avatar
    Morrow 30260
    x2... every time I use thinner head gaskets or 2 layers... I always run into sealing issues sometime down the road...
    use the stock one.
    Marietta, GA
    forget milling the head. that would be the last thing I did for compression. The closer the pistons and valves come together the more chance you have of interference between them. if you have the head off and you want higher compression just get some valves or pistons or something. besides, you won't build that much more compression by getting a thinner gasket alone.
    Morrow 30260
    Quote Originally Posted by integra82786
    yeah because adding a bigger domed pistons doesn't change internal clearances... hahahah wtf...
    hhaahha for real everyone thinks getting a big ass dome piston will give u 200 hp automatically, ive personally seen much retards spent money and just put CTR pistons in LS's and claim 200hp because there compression is higher than that of a type-r than they end up with a wimpy 140 and are like how come im not close to 200
    flat top valves
