Thread: valve spring question
    The names "Skeezy1" Samhonda95's Avatar
    South Ga. (Pelham)
    Default valve spring question
    I'm sure it's been asked before, but I can't find it. I have heard that to run ITR cams you run the ITR intake spring for the intake side (of course) and the GSR intake spring for the exhaust side. Is this true?
    Vuong's Garage Vuongy_Dong's Avatar
    Duluth, G-nett
    stock itr heads comes with dual valve springs on the intake side. its best to atleast run the dual springs on the intake side.
    South Ga. (Pelham)
    I have GSR head. I wan't to run ITR cams. Are the intake springs in a GSR head the same as ITR exhaust springs? From what I've heard, that's how you do it. So................is it true?
    Its not needed, i have several customers running around on stock GSR valvesprings an ITR cams or even Skunk2 Stage 1s.
    Just keep the Rev Limiter at 8200.
    If you witch to the ITR springs, you can run the revs to 8500.
    Custom Tuning By Daniel Willie.
    Parts, Fabrication, Race Car Prep
    770-319-9605 or [email protected]
    South Ga. (Pelham)
    Quote Originally Posted by Batlground
    Thanx.....that's what I needed to know.
    Marietta, GA
    yep, currently running itr cams in my gsr with no problems
