Results 1 to 15 of 15
Thread: gsr trans won't go into gear
    Enterprise AL,
    Default gsr trans won't go into gear
    I just bought a 94 cx hatch gsr swap about a month ago, and last night i went to a friends house. When i got back in the car would not go in reverse. Every other gear worked fine then my dumbass friend force it into reverse. Now it will go into any gear. Has anybody every heard of this, where do i need to start.
    pull it out, i can check it out for. Mainstream Performance 678-567-9834
    Don Mon SiRed94's Avatar
    Morrow 30260
    Quote Originally Posted by rsxdc52002
    when mine did that... i broke it down and one of the arms was broken off the shift fork... but anyhow... its something internal... send it to mainstream^^^
    its all about the B's brwloco's Avatar
    Doraville,GA
    same thing happened to... 5-R synchr was done for
    97' Acura Integra GSR
    180 @ 9,000 RPM
    my momma's house
    you better hope your out of clutch fluid, or low on tranny fluid. Anything else is screaming rebuild.
    Trend settin'
    Macon
    every once and a while mine won't go into reverse if I park on a hill unless I put it in a forward gear first. Then it works fine. It sounds like that may have been the original problem, but then your "friend" forced it into gear and bent something.
    Land Rover LR3 HSE
    Where Am I
    Yea honda's are known for their reverse being hard to get into to.......
    L'ville
    pump the clutch
    Enterprise AL,
    It's something internal pumped the clutch, changed the slave cyl. took the shift linage lose and nothing.I guess i,m going to take it out and buy another one. Anybody have one?
    You don't need reverse. Just park in parking spots were you do not need to back out. lol save 700 bucks.
    hmm yah bring it to a shop
    Enterprise AL,
    It won't go in to any gear at all. I got a ctr just sitting ,I could always put the lsd trans in it but I dont know which trans is best with a gsr any opinions?
    my momma's house
    If your going with a all motor setup, the CTR, hands down.
    Trend settin'
    Around metro-ATLANTA & IA!!
    Quote Originally Posted by TheChosenOne
    i concure...
    Certified Gearhead Pavlo's Avatar
    Alpharetta
    If it happened after "forcing" into gear, then it is most likely a bent or broken shift fork. Have fun.
    Representing VWs.
