Thread: X-303 CAM info
    5 litres of fun
    Hilton Head Island, SC
    Default X-303 CAM info
    i needed some info on the X-303 cam and i was having some trouble finding what i wanted on the net. if anyone has any info about the X-303 cam and or a site that gives me all the specs of ford letter cams that would be great thanks.
    90 Mustang GT
    BBK/Fidanza/Centerforce/JET
    Product Line: Ford Racing Camshafts
    Part Type: Camshafts
    Part Number: FMS-M-6250-X303
    Cam Style: Hydraulic roller tappet
    Intake Duration at 050 inch Lift: 224
    Exhaust Duration at 050 inch Lift: 224
    Duration at 050 inch Lift: 224 int./224 exh.
    Advertised Intake Duration: 286
    Advertised Exhaust Duration: 286
    Advertised Duration: 286 int./286 exh.
    Intake Valve Lift with Factory Rocker Arm Ratio: 0.542 in.
    Exhaust Valve Lift with Factory Rocker Arm Ratio: 0.542 in.
    Valve Lift with Factory Rocker Arm Ratio: 0.542 int./0.542 exh. lift
    Lobe Separation (degrees): 112
    Intake Valve Lash: 0.000 in.
    Exhaust Valve Lash: 0.000 in.
    Computer Controlled Compatible: Yes
    Grind Number: M-6250-X303
    Quantity: Sold individually.
    Notes: Will not work with Speed Density applications. A modified computer chip may be required.
    Camshaft, Hydraulic Roller Tappet, Advertised Duration 286/286, Lift .542/.542, Ford,
    its not a good street cam...I suggest a e-303 great for auto an 5 speed x303 is not good for auto unless you have a stall 2500 or higher
    X-cam won't work with stock pistons.
    depending on his pistons, it will , you will have to do a valve clearance check, or notch your pistons, easy to do, but that cam is just too much for a stock 5.0 get a E cam an be done with it, I ran a E cam an works fine
    Not to mention you need to do a complete valve train set up with some 1.6 rockers,double valve springs, lifters, unless you got money , use the E cam you be happy, sounds, great ...an is a good street cam, but still can be nice for the track
    He has a stock long block, it won't work.
    Yeah if its stock then yup!
    Quote Originally Posted by Init2winit
    my momma's house
    Wow, Josh fluent in "ford" as you are in "honda"...lol.
    Trend settin'
