Page 2 of 2 FirstFirst 12
Results 41 to 58 of 58
Thread: turbo gsr question .....
  1. #41
    by my nieghbor.........
    Quote Originally Posted by Big J
    Man I know you stay somewhere around where I work, hit me up w/ a address, I'd love to come check that thing out or give you a hand getting it back together.
    i will definetly let you know by saturday.
  2. #42
    I'll probably be at the shop tomorrow changing out a thermostat
  3. #43
    Certified Gearhead lsi-crvtec's Avatar
    That set up is good......for 400WHP
  4. #44
    Quote Originally Posted by lsi-crvtec
    thanks.
  5. #45
    1/2 Fast Motorsports highspeed's Avatar
    Gardendale AL
    i had a similar setup in my da......let scotty tune it......change the injectors and listen to the posts that have already been made....other wise you have got a good good setup....I made 318whp with rc440 and lsvtec with similar internals and that was almost too much for the street.....damn thing would get crazy in third gear on the xpress way.....good luck and want to know the nums when you get it tuned
  6. #46
    Quote Originally Posted by highspeed
    you got it homie. did you max out your injectors @ 318 hp ?
  7. #47
    Cool
    nice very nice good luck
    Quote Originally Posted by sc61equipped
    i have finally come to the end of my build and was wondering if i need to do anything else before i put the motor back together. i have everything minus sleeves.
    * forged je pistons 81mm ( 9:1) with manlley rods
    *str block gaurd
    *gsr head with itr valetrain ( 5 angled valve job , ported and polished )
    * honed/ decked/ hot tanked gsr block
    * balanced and blueprinted gsr crank
    *victor x intake manifold
    * presicion sc61 dual ball bearing turbo
    *650cc rc saturated injectors
    * ramhorn peakboost turbo manifold
    *acl main/rod bearings
    *cometic 3 layer head gasket
    *greddy fmic
    * 3 inch turbo back exhaust ( turbo n1)
    *p28 with chrome pro and conversion harness
    * all the ic pipings
    i know i have forgot some stuff , but you get the idea. i an hoping to be in the 350hp-375hp range. is it possible with this set up ?? lemme know what yall think.
  8. #48
    ^^ thanks homie.
  9. #49
    Atl
    I'd personally get a port and polish. I regretted not gettin that done. Don't forget the plastigauge and torque wrench!
    rite on
  10. #50
    02 WRX patrick4588's Avatar
    warner robins
    is this thing running yet?
    GCO Member
    NRA Member
  11. #51
    well i hit a little snag with the map sensor and had to order another one. will be running real soon.
  12. #52
    warner robins
    nice. think you can have it done before the track closes? i know silver dollar closes at the end of the month. im tryin to be able to make it out there. if you get yours done, we should meet up out there. would be cool to see two turbo gsr's running.
    GCO Member
    NRA Member
  13. #53
    @ballengine ballistic08's Avatar
    Grayson, Georgia
    what about ARP headstuds? idk how strong the stock bolts are.
    facebook.com/ballengine
  14. #54
    yes should be done this weekend. so i will shoot you a pm and we could head down to the track.
  15. #55
    Quote Originally Posted by ballistic08
    i have golden eagle headstuds so i should be good.
  16. #56
    warner robins
    ill be up that way to get tuned this weekend or early next week as long as the motor is fine. starting it up tonight. **crosses fingers**
    GCO Member
    NRA Member
  17. #57
    *** crossing my fingers also ***
  18. #58
    warner robins
    update update!!!
    GCO Member
    NRA Member
